SNMP v2c
Post Reply
ithwhip
SNMP v2c
Post by ithwhip »
not working ran command at prompt please help
llittle@l:~$ /usr/bin/cfgmaker --no-down --noreversedns --if-template=/usr/local/nagiosxi/html/includes/configwizards/switch/template --zero-speed '100000000' '[email protected]:161::::2'
Subroutine SNMP_Session::pack_sockaddr_in6 redefined at /usr/lib/x86_64-linux-gnu/perl-base/Exporter.pm line 63.
at /usr/bin/../lib/mrtg2/SNMP_Session.pm line 149.
Subroutine SNMP_Session::unpack_sockaddr_in6 redefined at /usr/lib/x86_64-linux-gnu/perl-base/Exporter.pm line 63.
Subroutine SNMPv1_Session::pack_sockaddr_in6 redefined at /usr/lib/x86_64-linux-gnu/perl-base/Exporter.pm line 63.
at /usr/bin/../lib/mrtg2/SNMP_Session.pm line 604.
Subroutine SNMPv1_Session::unpack_sockaddr_in6 redefined at /usr/lib/x86_64-linux-gnu/perl-base/Exporter.pm line 63.
--base: Get Device Info on [email protected]:161::::2
Use of uninitialized value $tempv in concatenation (.) or string at /usr/bin/../lib/mrtg2/SNMP_util.pm line 755.
Use of uninitialized value in concatenation (.) or string at /usr/bin/cfgmaker line 1006.
Use of uninitialized value in pattern match (m//) at /usr/bin/cfgmaker line 1008.
--base: Vendor Id: Unknown Vendor -
--base: Populating confcache
--base: Get Interface Info
Use of uninitialized value $descr in pattern match (m//) at /usr/bin/cfgmaker line 193.
--base: Walking ifIndex
--snpd: [email protected]:161::::2 -> 1.3.6.1.2.1.2.2.1.1 -> ifIndex =
--base: Walking ifType
--snpd: [email protected]:161::::2 -> 1.3.6.1.2.1.2.2.1.3 -> ifType =
--base: Walking ifAdminStatus
--snpd: [email protected]:161::::2 -> 1.3.6.1.2.1.2.2.1.7 -> ifAdminStatus =
--base: Walking ifOperStatus
--snpd: [email protected]:161::::2 -> 1.3.6.1.2.1.2.2.1.8 -> ifOperStatus =
--base: Walking ifMtu
--snpd: [email protected]:161::::2 -> 1.3.6.1.2.1.2.2.1.4 -> ifMtu =
--base: Walking ifSpeed
--snpd: @ifSpeed = 1.3.6.1.2.1.2.2.1.5:
--base: Walking ifHighSpeed
Argument "" isn't numeric in numeric eq (==) at /usr/bin/cfgmaker line 228.
Use of uninitialized value $descr in pattern match (m//) at /usr/bin/cfgmaker line 233.
Use of uninitialized value $syscontact in substitution (s///) at /usr/bin/cfgmaker line 380.
Use of uninitialized value $syslocation in substitution (s///) at /usr/bin/cfgmaker line 381.
Use of uninitialized value $comment_sysdescr in substitution (s///) at /usr/bin/cfgmaker line 382.
Use of uninitialized value $sysname in concatenation (.) or string at /usr/bin/cfgmaker line 415.
Use of uninitialized value $comment_sysdescr in concatenation (.) or string at /usr/bin/cfgmaker line 415.
Use of uninitialized value $syscontact in concatenation (.) or string at /usr/bin/cfgmaker line 415.
Use of uninitialized value $syslocation in concatenation (.) or string at /usr/bin/cfgmaker line 415.
# Created by
# /usr/bin/cfgmaker --no-down --noreversedns --if-template=/usr/local/nagiosxi/html/includes/configwizards/switch/template --zero-speed 100000000 [email protected]:161::::2
### Global Config Options
# for UNIX
# WorkDir: /home/http/mrtg
# or for NT
# WorkDir: c:\mrtgdata
### Global Defaults
# to get bits instead of bytes and graphs growing to the right
# Options[_]: growright, bits
EnableIPv6: no
# System:
# Description:
# Contact:
# Location:
danderson
Re: SNMP v2c
Post by danderson »
Can you tell me more about the version of XI you are using and which distro of linux this is installed on?
Post Reply
