Nagios Initial Setup with reverse proxy
Post Reply
Easily3227
Post by Easily3227 »
Hi all,
I am very new to Nagios. I am trying to set it up to monitor some services I am self-hosting.
I have followed the official setup https://support.nagios.com/kb/article/n ... ml#Ubuntul (Ubuntu 22.04).
I can access Nagios at
http://<publicIP>/nagios
However, I use Gravitational Teleport as my security gateway/reverse proxy. And as soon as I put teleport in front of nagios, I cannot access nagios.
Teleport works by having an agent installed on the same vm/vps that is running Nagios and any traffic coming from teleport looks to the machine/vm to be coming from localhost. From the same VM/VPS that is running nagios, I can run
curl http://localhost/nagios/
and that works.
However, Teleport, cannot access localhost/nagios. (localhost) works though and shows the apache default page.
I assume it has something to do with the apache config (I don't know apache at all).
# SSLRequireSSL
Options ExecCGI
AllowOverride None
<IfVersion >= 2.3>
<RequireAll>
Require all granted
# Require host 127.0.0.1
#AuthName Nagios Access
#AuthType Basic
#AuthUserFile /usr/local/nagios/etc/htpasswd.users
#Require valid-user
</RequireAll>
</IfVersion>
<IfVersion < 2.3>
Order allow,deny
Allow from all
# Order deny,allow
# Deny from all
# Allow from 127.0.0.1
#AuthType Basic
#Require valid-user
</IfVersion>
</Directory>
Alias /nagios "/usr/local/nagios/share"
<Directory "/usr/local/nagios/share">
# SSLRequireSSL
Options None
AllowOverride None
<IfVersion >= 2.3>
<RequireAll>
Require all granted
#AuthType Basic
#Require valid-user
</RequireAll>
</IfVersion>
<IfVersion < 2.3>
Order allow,deny
Allow from all
# Order deny,allow
# Deny from all
#AuthType Basic
#Require valid-user
</IfVersion>
</Directory>
I am hoping someone can point me in the right direction.
Here is the apache config. It is the default one created from the default install of Nagios, however I have disabled all authentication as that will be handled by teleport.
I have also posted this on the Teleport forums. Thank you very much for any help.
bbahn
Re: Nagios Initial Setup with reverse proxy
Post by bbahn »
Hello @Easily3227,
I'm not familiar with Gravitational Teleport, but your Apache configuration looks good to me.
Since this isn't working for you and your apache configuration is what's listed in your post, my guess is that Gravitational Teleport isn't routing to Apache properly (assuming you restarted apache to apply the configuration).
You can also check if it's the firewall with
sudo ufw allow 'Apache Full'
Easily3227
I had previously tried all that. I have no idea what is going on. But thanks for validating the Apache config:)
Post Reply
