When I tried to make changes into the file "/usr/local/nagios/etc/objects/windows.cfg" and after making restarting the service I am getting the error as nagios.service - Nagios Core 4.5.3
Loaded: loaded (/lib/systemd/system/nagios.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2024-07-22 05:59:18 CDT; 5min ago
Docs: https://www.nagios.org/documentation
Process: 2576445 ExecStartPre=/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg (code=exited, status=1/FAILURE)
Process: 2576446 ExecStopPost=/usr/bin/rm -f /usr/local/nagios/var/rw/nagios.cmd (code=exited, status=0/SUCCESS)
CPU: 9ms
Nagios 4.5.3 service issue
Re: Nagios 4.5.3 service issue
Hello @mandar18,
Have you tried running the following to verify your configuration?:
It sounds like your configuration may not be correct and the above command will indicate whether your configuration is correct or not in most cases.
/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfgActively advancing awesome answers with ardent alliteration, aptly addressing all ambiguities. Amplify your acumen and avail our amicable assistance. Eagerly awaiting your astute assessments of our advice.
I found the issue, and it was resolved.
Thank you.
Thank you.
