observing more disk space utilization post migration
Post Reply
pavan509
Post by pavan509 »
Hello Team,
we have done the migration of NagiosXI 2024R1.1.1 from RHEL 7 to RHEL 9 in the month of April and May on our Dev and Prod environments. In the Dev environment, I could see the root partition and log files size are gradually increasing. one reason can be there are hosts and services where the checks are failing due to firewall port restriction initially. I identified and removed such hosts and services in the Dev environment as they are no longer required. When I raised an internal ticket to server team, they provided the below directory is occupying more space and asking me to confirm if this directory is related to application or not. If yes, how should we deal with it.
 sudo du -sh  /var/log/sudo-io/00
25G     /var/log/sudo-io/00
sudo ls -lrth  /var/log/sudo-io/00
total 32M
drwx------. 1297 root root  24K Mar 15 13:51 00
drwx------. 1298 root root  24K Apr 19 13:22 01
drwx------  1298 root root  24K Apr 19 16:38 02
drwx------  1298 root root  24K Apr 19 19:54 03
drwx------  1298 root root  24K Apr 19 23:10 04
drwx------  1298 root root  24K Apr 20 02:27 05
drwx------  1298 root root  24K Apr 20 05:43 06
drwx------  1298 root root  24K Apr 20 09:00 07
drwx------  1298 root root  24K Apr 20 12:16 08
drwx------  1298 root root  24K Apr 20 15:32 09
drwx------  1298 root root  24K Apr 20 18:49 0A
drwx------  1298 root root  24K Apr 20 22:05 0B
drwx------  1298 root root  24K Apr 21 01:21 0C
drwx------  1298 root root  24K Apr 21 04:38 0D
drwx------  1298 root root  24K Apr 21 07:54 0E
drwx------  1298 root root  24K Apr 21 11:10 0F
drwx------  1298 root root  24K Apr 21 14:26 0G
drwx------  1298 root root  24K Apr 21 17:42 0H
drwx------  1298 root root  24K Apr 21 20:59 0I
drwx------  1298 root root  24K Apr 22 00:15 0J
drwx------  1298 root root  24K Apr 22 03:31 0K
drwx------  1298 root root  24K Apr 22 06:48 0L
drwx------  1298 root root  24K Apr 22 10:04 0M
drwx------  1298 root root  24K Apr 22 13:20 0N
drwx------  1298 root root  24K Apr 22 16:37 0O
drwx------  1298 root root  24K Apr 22 19:53 0P
drwx------  1298 root root  24K Apr 29 20:41 0Q
drwx------  1298 root root  24K Apr 29 23:57 0R
drwx------  1298 root root  24K Apr 30 03:14 0S
drwx------  1298 root root  24K Apr 30 06:30 0T
drwx------  1298 root root  24K Apr 30 09:45 0U
drwx------  1298 root root  24K Apr 30 14:27 0V
drwx------  1298 root root  24K Apr 30 18:02 0W
drwx------  1298 root root  24K Apr 30 21:35 0X
drwx------  1298 root root  24K May  1 01:11 0Y
drwx------  1298 root root  24K May  1 04:47 0Z
drwx------  1298 root root  24K May  1 08:21 10
drwx------  1298 root root  24K May  1 11:55 11
drwx------  1298 root root  24K May  1 15:31 12
drwx------  1298 root root  24K May  1 19:07 13
drwx------  1298 root root  24K May  3 10:55 14
drwx------  1298 root root  24K May  3 14:29 15
drwx------  1298 root root  24K May  3 18:01 16
drwx------  1298 root root  24K May  3 21:37 17
drwx------  1298 root root  24K May  4 01:13 18
drwx------  1298 root root  24K May  4 04:49 19
drwx------  1298 root root  24K May  4 08:25 1A
drwx------  1298 root root  24K May  4 11:56 1B
drwx------  1298 root root  24K May  4 15:32 1C
drwx------  1298 root root  24K May  4 19:08 1D
drwx------  1298 root root  24K May  4 22:44 1E
drwx------  1298 root root  24K May  5 02:20 1F
drwx------  1298 root root  24K May  5 05:56 1G
drwx------  1298 root root  24K May  5 09:32 1H
drwx------  1298 root root  24K May  5 13:08 1I
drwx------  1298 root root  24K May  5 16:44 1J
drwx------  1298 root root  24K May  5 20:20 1K
drwx------  1298 root root  24K May  5 23:56 1L
drwx------  1298 root root  24K May  6 03:31 1M
drwx------  1298 root root  24K May  6 07:07 1N
drwx------  1298 root root  24K May  6 10:43 1O
drwx------  1298 root root  24K May  6 14:19 1P
drwx------  1298 root root  24K May  6 17:55 1Q
drwx------  1298 root root  24K May  6 21:31 1R
drwx------  1298 root root  24K May  7 01:07 1S
drwx------  1298 root root  24K May  7 04:43 1T
drwx------  1298 root root  24K May  7 08:19 1U
drwx------  1298 root root  24K May  7 11:53 1V
drwx------  1298 root root  24K May  7 15:29 1W
drwx------  1298 root root  24K May  7 19:04 1X
drwx------  1298 root root  24K May  7 22:40 1Y
drwx------  1298 root root  24K May  8 02:16 1Z
drwx------  1298 root root  24K May  8 05:52 20
drwx------  1298 root root  24K May  8 09:27 21
drwx------  1298 root root  24K May  8 13:03 22
drwx------  1298 root root  24K May  8 16:37 23
drwx------  1298 root root  24K May  8 20:06 24
drwx------  1298 root root  24K May  8 23:40 25
drwx------  1298 root root  24K May  9 03:16 26
drwx------  1298 root root  24K May  9 06:52 27
drwx------  1298 root root  24K May  9 10:27 28
drwx------  1298 root root  24K May  9 14:03 29
drwx------  1298 root root  24K May  9 17:39 2A
drwx------  1298 root root  24K May  9 21:15 2B
drwx------  1298 root root  24K May 10 00:51 2C
drwx------  1298 root root  24K May 10 04:27 2D
drwx------  1298 root root  24K May 10 08:03 2E
drwx------  1298 root root  24K May 10 11:38 2F
drwx------  1298 root root  24K May 10 15:12 2G
drwx------  1298 root root  24K May 10 18:48 2H
drwx------  1298 root root  24K May 10 22:24 2I
drwx------  1298 root root  24K May 11 02:00 2J
drwx------  1298 root root  24K May 11 05:36 2K
drwx------  1298 root root  24K May 11 09:11 2L
drwx------  1298 root root  24K May 11 12:47 2M
drwx------  1298 root root  24K May 11 16:23 2N
drwx------  1298 root root  24K May 11 19:59 2O
drwx------  1298 root root  24K May 11 23:35 2P
drwx------  1298 root root  24K May 12 03:11 2Q
drwx------  1298 root root  24K May 12 06:47 2R
drwx------  1298 root root  24K May 12 10:23 2S
drwx------  1298 root root  24K May 12 13:59 2T
drwx------  1298 root root  24K May 12 17:35 2U
drwx------  1298 root root  24K May 12 21:11 2V
drwx------  1298 root root  24K May 13 00:47 2W
drwx------  1298 root root  24K May 13 04:23 2X
drwx------  1298 root root  24K May 13 07:59 2Y
drwx------  1298 root root  24K May 13 11:34 2Z
drwx------  1298 root root  24K May 13 15:10 30
drwx------  1298 root root  24K May 13 18:46 31
drwx------  1298 root root  24K May 13 22:22 32
drwx------  1298 root root  24K May 14 01:58 33
drwx------  1298 root root  24K May 14 05:34 34
drwx------  1298 root root  24K May 14 09:10 35
drwx------  1298 root root  24K May 14 12:46 36
drwx------  1298 root root  24K May 14 16:34 37
drwx------  1298 root root  24K May 14 20:06 38
drwx------  1298 root root  24K May 14 23:42 39
drwx------  1298 root root  24K May 15 03:18 3A
drwx------  1298 root root  24K May 15 06:54 3B
drwx------  1298 root root  24K May 15 10:29 3C
drwx------  1298 root root  24K May 15 14:03 3D
drwx------  1298 root root  24K May 15 17:38 3E
drwx------  1298 root root  24K May 15 21:14 3F
drwx------  1298 root root  24K May 16 00:50 3G
drwx------  1298 root root  24K May 16 04:25 3H
drwx------  1298 root root  24K May 16 08:01 3I
drwx------  1298 root root  24K May 16 11:37 3J
drwx------  1298 root root  24K May 16 15:13 3K
drwx------  1298 root root  24K May 16 18:49 3L
drwx------  1298 root root  24K May 16 22:25 3M
drwx------  1298 root root  24K May 17 02:01 3N
drwx------  1298 root root  24K May 17 05:37 3O
drwx------  1298 root root  24K May 17 09:13 3P
drwx------  1298 root root  24K May 17 12:48 3Q
drwx------  1298 root root  24K May 17 16:22 3R
drwx------  1298 root root  24K May 17 19:55 3S
drwx------  1298 root root  24K May 17 23:31 3T
drwx------  1298 root root  24K May 18 03:07 3U
drwx------  1298 root root  24K May 18 06:43 3V
drwx------  1298 root root  24K May 18 10:19 3W
drwx------  1298 root root  24K May 18 13:55 3X
drwx------  1298 root root  24K May 18 17:31 3Y
drwx------  1298 root root  24K May 18 21:07 3Z
drwx------  1298 root root  24K May 19 00:43 40
drwx------  1298 root root  24K May 19 04:19 41
drwx------  1298 root root  24K May 19 07:55 42
drwx------  1298 root root  24K May 19 11:30 43
drwx------  1298 root root  24K May 19 15:06 44
drwx------  1298 root root  24K May 19 18:42 45
drwx------  1298 root root  24K May 19 22:18 46
drwx------  1298 root root  24K May 20 01:54 47
drwx------  1298 root root  24K May 20 05:30 48
drwx------  1298 root root  24K May 20 09:05 49
drwx------  1298 root root  24K May 20 12:36 4A
drwx------  1298 root root  24K May 20 16:10 4B
drwx------  1298 root root  24K May 20 19:46 4C
drwx------  1298 root root  24K May 20 23:22 4D
drwx------  1298 root root  24K May 21 02:58 4E
drwx------  1298 root root  24K May 21 06:34 4F
drwx------  1298 root root  24K May 21 10:07 4G
drwx------  1298 root root  24K May 21 13:42 4H
drwx------  1298 root root  24K May 21 17:18 4I
drwx------  1298 root root  24K May 21 20:54 4J
drwx------  1298 root root  24K May 22 00:30 4K
drwx------  1298 root root  24K May 22 04:06 4L
drwx------  1298 root root  24K May 22 07:42 4M
drwx------  1298 root root  24K May 22 11:17 4N
drwx------  1298 root root  24K May 22 14:53 4O
drwx------  1298 root root  24K May 22 18:29 4P
drwx------  1298 root root  24K May 22 22:05 4Q
drwx------  1298 root root  24K May 23 01:41 4R
drwx------  1298 root root  24K May 23 05:17 4S
drwx------  1298 root root  24K May 23 08:53 4T
drwx------  1298 root root  24K May 23 12:28 4U
drwx------  1298 root root  24K May 23 16:04 4V
drwx------  1298 root root  24K May 23 19:39 4W
drwx------  1298 root root  24K May 23 23:15 4X
drwx------  1298 root root  24K May 24 02:51 4Y
drwx------  1298 root root  24K May 24 06:27 4Z
drwx------  1298 root root  24K May 24 10:00 50
drwx------  1298 root root  24K May 24 13:36 51
drwx------  1298 root root  24K May 24 17:08 52
drwx------  1298 root root  24K May 24 20:44 53
drwx------  1298 root root  24K May 25 00:20 54
drwx------  1298 root root  24K May 25 03:55 55
drwx------  1298 root root  24K May 25 07:31 56
drwx------  1298 root root  24K May 25 11:07 57
drwx------  1298 root root  24K May 25 14:43 58
drwx------  1298 root root  24K May 25 18:19 59
drwx------  1298 root root  24K May 25 21:55 5A
drwx------  1298 root root  24K May 26 01:31 5B
drwx------  1298 root root  24K May 26 05:07 5C
drwx------  1298 root root  24K May 26 08:43 5D
drwx------  1298 root root  24K May 26 12:19 5E
drwx------  1298 root root  24K May 26 15:55 5F
drwx------  1298 root root  24K May 26 19:31 5G
drwx------  1298 root root  24K May 26 23:07 5H
drwx------  1298 root root  24K May 27 02:43 5I
drwx------  1298 root root  24K May 27 06:19 5J
drwx------  1298 root root  24K May 27 09:55 5K
drwx------  1298 root root  24K May 27 13:30 5L
drwx------  1298 root root  24K May 27 17:04 5M
drwx------  1298 root root  24K May 27 20:40 5N
drwx------  1298 root root  24K May 28 00:16 5O
drwx------  1298 root root  24K May 28 03:52 5P
drwx------  1298 root root  24K May 28 07:28 5Q
drwx------  1298 root root  24K May 28 11:03 5R
drwx------  1298 root root  24K May 28 14:38 5S
drwx------  1298 root root  24K May 28 18:14 5T
drwx------  1298 root root  24K Jun  3 12:57 5U
drwx------  1298 root root  24K Jun  3 16:32 5V
drwx------  1298 root root  24K Jun  3 20:06 5W
drwx------  1298 root root  24K Jun  3 23:42 5X
drwx------  1298 root root  24K Jun  4 03:18 5Y
drwx------  1298 root root  24K Jun  4 06:54 5Z
drwx------  1298 root root  24K Jun  4 10:29 60
drwx------  1298 root root  24K Jun  4 14:04 61
drwx------  1298 root root  24K Jun  4 17:39 62
drwx------  1298 root root  24K Jun  4 21:06 63
drwx------  1298 root root  24K Jun  5 00:42 64
drwx------  1298 root root  24K Jun  5 04:17 65
drwx------  1298 root root  24K Jun  5 07:53 66
drwx------  1298 root root  24K Jun  5 11:28 67
drwx------  1298 root root  24K Jun  5 15:03 68
drwx------  1298 root root  24K Jun  5 18:39 69
drwx------  1298 root root  24K Jun  5 22:15 6A
drwx------  1298 root root  24K Jun  6 01:51 6B
drwx------  1298 root root  24K Jun  6 05:27 6C
drwx------  1298 root root  24K Jun  6 09:03 6D
drwx------  1298 root root  24K Jun  6 12:38 6E
drwx------  1298 root root  24K Jun  6 16:14 6F
drwx------  1298 root root  24K Jun  6 19:50 6G
drwx------  1298 root root  24K Jun  6 23:26 6H
drwx------  1298 root root  24K Jun  7 03:02 6I
drwx------  1298 root root  24K Jun  7 06:38 6J
drwx------  1298 root root  24K Jun  7 10:14 6K
drwx------  1298 root root  24K Jun  7 13:49 6L
drwx------  1298 root root  24K Jun  7 17:25 6M
drwx------  1298 root root  24K Jun  7 21:01 6N
drwx------  1298 root root  24K Jun  8 00:37 6O
drwx------  1298 root root  24K Jun  8 04:13 6P
drwx------  1298 root root  24K Jun  8 07:49 6Q
drwx------  1298 root root  24K Jun  8 11:21 6R
drwx------  1298 root root  24K Jun  8 14:57 6S
drwx------  1298 root root  24K Jun  8 18:33 6T
drwx------  1298 root root  24K Jun  8 22:09 6U
drwx------  1298 root root  24K Jun  9 01:44 6V
drwx------  1298 root root  24K Jun  9 05:20 6W
drwx------  1298 root root  24K Jun  9 08:53 6X
drwx------  1298 root root  24K Jun  9 12:28 6Y
drwx------  1298 root root  24K Jun  9 16:04 6Z
drwx------  1298 root root  24K Jun  9 19:40 70
drwx------  1298 root root  24K Jun  9 23:13 71
drwx------  1298 root root  24K Jun 10 02:48 72
drwx------  1298 root root  24K Jun 10 06:24 73
drwx------  1298 root root  24K Jun 10 10:00 74
drwx------  1298 root root  24K Jun 10 13:34 75
drwx------  1298 root root  24K Jun 10 17:06 76
drwx------  1298 root root  24K Jun 10 20:42 77
drwx------  1298 root root  24K Jun 11 00:18 78
drwx------  1298 root root  24K Jun 11 03:53 79
drwx------  1298 root root  24K Jun 11 07:29 7A
drwx------  1298 root root  24K Jun 11 11:05 7B
drwx------  1298 root root  24K Jun 11 14:36 7C
drwx------  1298 root root  24K Jun 11 18:12 7D
drwx------  1298 root root  24K Jun 11 21:47 7E
drwx------  1298 root root  24K Jun 12 01:23 7F
drwx------  1298 root root  24K Jun 12 04:59 7G
drwx------  1298 root root  24K Jun 12 08:34 7H
drwx------  1298 root root  24K Jun 12 12:09 7I
drwx------  1298 root root  24K Jun 12 15:45 7J
drwx------  1298 root root  24K Jun 12 19:20 7K
drwx------  1298 root root  24K Jun 12 22:56 7L
drwx------  1298 root root  24K Jun 13 02:32 7M
drwx------  1298 root root  24K Jun 13 06:08 7N
drwx------  1298 root root  24K Jun 13 09:43 7O
drwx------  1298 root root  24K Jun 13 13:17 7P
drwx------  1298 root root  24K Jun 13 16:52 7Q
drwx------  1298 root root  24K Jun 13 20:27 7R
drwx------  1298 root root  24K Jun 14 00:03 7S
drwx------  1298 root root  24K Jun 14 03:39 7T
drwx------  1298 root root  24K Jun 14 07:16 7U
drwx------  1298 root root  24K Jun 14 10:51 7V
drwx------  1298 root root  24K Jun 14 14:27 7W
drwx------  1298 root root  24K Jun 14 18:03 7X
drwx------  1298 root root  24K Jun 14 21:39 7Y
drwx------  1298 root root  24K Jun 15 01:15 7Z
drwx------  1298 root root  24K Jun 15 04:51 80
drwx------  1298 root root  24K Jun 15 08:26 81
drwx------  1298 root root  24K Jun 15 11:59 82
drwx------  1298 root root  24K Jun 15 15:35 83
drwx------  1298 root root  24K Jun 15 19:11 84
drwx------  1298 root root  24K Jun 15 22:47 85
drwx------  1298 root root  24K Jun 16 02:23 86
drwx------  1298 root root  24K Jun 16 05:58 87
drwx------  1298 root root  24K Jun 16 09:31 88
drwx------  1298 root root  24K Jun 16 13:07 89
drwx------  1298 root root  24K Jun 16 16:43 8A
drwx------  1298 root root  24K Jun 16 20:19 8B
drwx------  1298 root root  24K Jun 16 23:55 8C
drwx------  1298 root root  24K Jun 17 03:31 8D
drwx------  1298 root root  24K Jun 17 07:07 8E
drwx------  1298 root root  24K Jun 17 10:43 8F
drwx------  1298 root root  24K Jun 17 14:19 8G
drwx------  1298 root root  24K Jun 17 17:55 8H
drwx------  1298 root root  24K Jun 17 21:31 8I
drwx------  1298 root root  24K Jun 18 01:07 8J
drwx------  1298 root root  24K Jun 18 04:43 8K
drwx------  1298 root root  24K Jun 18 08:19 8L
drwx------  1298 root root  24K Jun 18 11:54 8M
drwx------  1298 root root  24K Jun 18 15:30 8N
drwx------  1298 root root  24K Jun 18 19:06 8O
drwx------  1298 root root  24K Jun 18 22:42 8P
drwx------  1298 root root  24K Jun 19 02:18 8Q
drwx------  1298 root root  24K Jun 19 05:54 8R
drwx------  1298 root root  24K Jun 19 09:30 8S
drwx------  1298 root root  24K Jun 19 13:06 8T
drwx------  1298 root root  24K Jun 19 16:41 8U
drwx------  1298 root root  24K Jun 19 20:17 8V
drwx------  1298 root root  24K Jun 19 23:53 8W
drwx------  1298 root root  24K Jun 20 03:29 8X
drwx------  1298 root root  24K Jun 20 07:05 8Y
drwx------  1298 root root  24K Jun 20 10:38 8Z
drwx------  1298 root root  24K Jun 20 14:13 90
drwx------  1298 root root  24K Jun 20 17:49 91
drwx------  1298 root root  24K Jun 20 21:21 92
drwx------  1298 root root  24K Jun 21 00:57 93
drwx------  1298 root root  24K Jun 21 04:33 94
drwx------  1298 root root  24K Jun 21 08:09 95
drwx------  1298 root root  24K Jun 21 11:45 96
drwx------  1298 root root  24K Jun 21 15:16 97
drwx------  1298 root root  24K Jun 21 18:51 98
drwx------  1298 root root  24K Jun 21 22:27 99
drwx------  1298 root root  24K Jun 22 02:03 9A
drwx------  1298 root root  24K Jun 22 05:39 9B
drwx------  1298 root root  24K Jun 22 09:11 9C
drwx------  1298 root root  24K Jun 22 12:47 9D
drwx------  1298 root root  24K Jun 22 16:23 9E
drwx------  1298 root root  24K Jun 22 19:59 9F
drwx------  1298 root root  24K Jun 22 23:35 9G
drwx------  1298 root root  24K Jun 23 03:11 9H
drwx------  1298 root root  24K Jun 23 06:47 9I
drwx------  1298 root root  24K Jun 23 10:23 9J
drwx------  1298 root root  24K Jun 23 13:58 9K
drwx------  1298 root root  24K Jun 23 17:34 9L
drwx------  1298 root root  24K Jun 23 21:09 9M
drwx------  1298 root root  24K Jun 24 00:43 9N
drwx------  1298 root root  24K Jun 24 04:18 9O
drwx------  1298 root root  24K Jun 24 07:54 9P
drwx------  1298 root root  24K Jun 24 11:30 9Q
drwx------  1298 root root  24K Jun 24 15:01 9R
drwx------  1298 root root  24K Jun 24 18:37 9S
drwx------  1298 root root  24K Jun 24 22:13 9T
drwx------  1298 root root  24K Jun 25 01:49 9U
drwx------  1298 root root  24K Jun 25 05:25 9V
drwx------  1298 root root  24K Jun 25 09:01 9W
drwx------  1298 root root  24K Jun 25 12:35 9X
drwx------  1298 root root  24K Jun 25 16:11 9Y
drwx------  1298 root root  24K Jun 25 19:45 9Z
drwx------  1298 root root  24K Jun 25 23:21 A0
drwx------  1298 root root  24K Jun 26 02:57 A1
drwx------  1298 root root  24K Jun 26 06:33 A2
drwx------  1298 root root  24K Jun 26 10:09 A3
drwx------  1298 root root  24K Jun 26 13:45 A4
drwx------  1298 root root  24K Jun 26 17:20 A5
drwx------  1298 root root  24K Jun 26 20:55 A6
drwx------  1298 root root  24K Jun 27 00:31 A7
drwx------  1298 root root  24K Jun 27 04:06 A8
drwx------  1298 root root  24K Jun 27 07:42 A9
drwx------  1298 root root  24K Jun 27 11:18 AA
drwx------  1298 root root  24K Jun 27 14:53 AB
drwx------  1298 root root  24K Jun 27 18:29 AC
drwx------  1298 root root  24K Jun 27 22:05 AD
drwx------  1298 root root  24K Jun 28 01:41 AE
drwx------  1298 root root  24K Jun 28 05:17 AF
drwx------  1298 root root  24K Jun 28 08:53 AG
drwx------  1298 root root  24K Jun 28 12:29 AH
drwx------  1298 root root  24K Jun 28 16:05 AI
drwx------  1298 root root  24K Jun 28 19:41 AJ
drwx------  1298 root root  24K Jun 28 23:17 AK
drwx------  1298 root root  24K Jun 29 02:53 AL
drwx------  1298 root root  24K Jun 29 06:29 AM
drwx------  1298 root root  24K Jun 29 10:01 AN
drwx------  1298 root root  24K Jun 29 13:37 AO
drwx------  1298 root root  24K Jun 29 17:13 AP
drwx------  1298 root root  24K Jun 29 20:49 AQ
drwx------  1298 root root  24K Jun 30 00:25 AR
drwx------  1298 root root  24K Jun 30 04:01 AS
drwx------  1298 root root  24K Jun 30 07:33 AT
drwx------  1298 root root  24K Jun 30 11:09 AU
drwx------  1298 root root  24K Jun 30 14:45 AV
drwx------  1298 root root  24K Jun 30 18:21 AW
drwx------  1298 root root  24K Jun 30 21:53 AX
drwx------  1298 root root  24K Jul  1 01:29 AY
drwx------  1298 root root  24K Jul  1 05:05 AZ
drwx------  1298 root root  24K Jul  1 08:40 B0
drwx------  1298 root root  24K Jul  1 12:16 B1
drwx------  1298 root root  24K Jul  1 15:51 B2
drwx------  1298 root root  24K Jul  1 19:27 B3
drwx------  1298 root root  24K Jul  1 23:03 B4
drwx------  1298 root root  24K Jul  2 02:39 B5
drwx------  1298 root root  24K Jul  2 06:15 B6
drwx------  1298 root root  24K Jul  2 09:51 B7
drwx------  1298 root root  24K Jul  2 13:27 B8
drwx------  1298 root root  24K Jul  2 17:03 B9
drwx------  1298 root root  24K Jul  2 20:39 BA
drwx------  1298 root root  24K Jul  3 00:15 BB
drwx------  1298 root root  24K Jul  3 03:51 BC
drwx------  1298 root root  24K Jul  3 07:27 BD
drwx------  1298 root root  24K Jul  3 11:03 BE
drwx------  1298 root root  24K Jul  3 14:39 BF
drwx------  1298 root root  24K Jul  3 18:15 BG
drwx------  1298 root root  24K Jul  3 21:51 BH
drwx------  1298 root root  24K Jul  4 01:27 BI
drwx------  1298 root root  24K Jul  4 05:03 BJ
drwx------  1298 root root  24K Jul  4 08:39 BK
drwx------  1298 root root  24K Jul  4 12:14 BL
drwx------  1298 root root  24K Jul  4 15:50 BM
drwx------  1298 root root  24K Jul  4 19:24 BN
drwx------  1298 root root  24K Jul  4 23:00 BO
drwx------  1298 root root  24K Jul  5 02:36 BP
drwx------  1298 root root  24K Jul  5 06:12 BQ
drwx------  1298 root root  24K Jul  5 09:47 BR
drwx------  1298 root root  24K Jul  5 13:19 BS
drwx------  1298 root root  24K Jul  5 16:55 BT
drwx------  1298 root root  24K Jul  5 20:31 BU
drwx------  1298 root root  24K Jul  6 00:07 BV
drwx------  1298 root root  24K Jul  6 03:43 BW
drwx------  1298 root root  24K Jul  6 07:19 BX
drwx------  1298 root root  24K Jul  6 10:51 BY
drwx------  1298 root root  24K Jul  6 14:27 BZ
drwx------  1298 root root  24K Jul  6 18:03 C0
drwx------  1298 root root  24K Jul  6 21:39 C1
drwx------  1298 root root  24K Jul  7 01:14 C2
drwx------  1298 root root  24K Jul  7 04:50 C3
drwx------  1298 root root  24K Jul  7 08:26 C4
drwx------  1298 root root  24K Jul  7 12:02 C5
drwx------  1298 root root  24K Jul  7 15:38 C6
drwx------  1298 root root  24K Jul  7 19:14 C7
drwx------  1298 root root  24K Jul  7 22:50 C8
drwx------  1298 root root  24K Jul  8 02:26 C9
drwx------  1298 root root  24K Jul  8 06:02 CA
drwx------  1298 root root  24K Jul  8 09:36 CB
drwx------  1298 root root  24K Jul  8 13:03 CC
drwx------  1298 root root  24K Jul  8 16:39 CD
drwx------  1298 root root  24K Jul  8 20:14 CE
drwx------  1298 root root  24K Jul  8 23:50 CF
drwx------  1298 root root  24K Jul  9 03:26 CG
drwx------  1298 root root  24K Jul  9 07:02 CH
drwx------  1298 root root  24K Jul  9 10:38 CI
drwx------  1298 root root  24K Jul  9 14:14 CJ
drwx------  1298 root root  24K Jul  9 17:50 CK
drwx------  1298 root root  24K Jul  9 21:26 CL
drwx------  1298 root root  24K Jul 10 01:02 CM
drwx------  1298 root root  24K Jul 10 04:38 CN
drwx------  1298 root root  24K Jul 10 08:14 CO
drwx------  1298 root root  24K Jul 10 11:50 CP
drwx------  1298 root root  24K Jul 10 15:25 CQ
drwx------  1298 root root  24K Jul 10 18:57 CR
drwx------  1298 root root  24K Jul 10 22:30 CS
drwx------  1298 root root  24K Jul 11 02:06 CT
drwx------  1298 root root  24K Jul 11 05:42 CU
drwx------  1298 root root  24K Jul 11 09:18 CV
drwx------  1298 root root  24K Jul 11 12:54 CW
drwx------  1298 root root  24K Jul 11 16:28 CX
drwx------  1298 root root  24K Jul 11 20:04 CY
drwx------  1298 root root  24K Jul 11 23:40 CZ
drwx------  1298 root root  24K Jul 12 03:15 D0
drwx------  1298 root root  24K Jul 12 06:51 D1
drwx------  1298 root root  24K Jul 12 10:27 D2
drwx------  1298 root root  24K Jul 12 14:02 D3
drwx------  1298 root root  24K Jul 12 17:38 D4
drwx------  1298 root root  24K Jul 12 21:14 D5
drwx------  1298 root root  24K Jul 13 00:50 D6
drwx------  1298 root root  24K Jul 13 04:25 D7
drwx------  1298 root root  24K Jul 13 08:00 D8
drwx------  1298 root root  24K Jul 13 11:33 D9
drwx------  1298 root root  24K Jul 13 15:09 DA
drwx------  1298 root root  24K Jul 13 18:45 DB
drwx------  1298 root root  24K Jul 13 22:21 DC
drwx------  1298 root root  24K Jul 14 01:57 DD
drwx------  1298 root root  24K Jul 14 05:33 DE
drwx------  1298 root root  24K Jul 14 09:09 DF
drwx------  1298 root root  24K Jul 14 12:45 DG
drwx------  1298 root root  24K Jul 14 16:21 DH
drwx------  1298 root root  24K Jul 14 19:57 DI
drwx------  1298 root root  24K Jul 14 23:33 DJ
drwx------  1298 root root  24K Jul 15 03:08 DK
drwx------  1298 root root  24K Jul 15 06:44 DL
drwx------  1298 root root  24K Jul 15 10:20 DM
drwx------  1298 root root  24K Jul 15 13:56 DN
drwx------  1298 root root  24K Jul 15 17:32 DO
drwx------  1298 root root  24K Jul 15 21:08 DP
drwx------  1298 root root  24K Jul 16 00:44 DQ
drwx------  1298 root root  24K Jul 16 04:19 DR
drwx------  1298 root root  24K Jul 16 07:56 DS
drwx------  1298 root root  24K Jul 16 11:32 DT
drwx------  1298 root root  24K Jul 16 15:08 DU
drwx------  1298 root root  24K Jul 16 18:44 DV
drwx------  1298 root root  24K Jul 16 22:20 DW
drwx------  1298 root root  24K Jul 17 01:55 DX
drwx------  1298 root root  24K Jul 17 05:31 DY
drwx------  1298 root root  24K Jul 17 09:08 DZ
drwx------  1298 root root  24K Jul 17 12:43 E0
drwx------  1298 root root  24K Jul 17 16:16 E1
drwx------  1298 root root  24K Jul 17 19:51 E2
drwx------  1298 root root  24K Jul 17 23:27 E3
drwx------  1298 root root  24K Jul 18 03:03 E4
drwx------  1298 root root  24K Jul 18 06:39 E5
drwx------  1298 root root  24K Jul 18 10:15 E6
drwx------  1298 root root  24K Jul 18 13:49 E7
drwx------  1298 root root  24K Jul 18 17:25 E8
drwx------  1298 root root  24K Jul 18 21:01 E9
drwx------  1298 root root  24K Jul 19 00:37 EA
drwx------  1298 root root  24K Jul 19 04:12 EB
drwx------  1298 root root  24K Jul 19 07:48 EC
drwx------  1298 root root  24K Jul 19 11:24 ED
drwx------  1298 root root  24K Jul 19 14:59 EE
drwx------  1298 root root  24K Jul 19 18:35 EF
drwx------  1298 root root  24K Jul 19 22:11 EG
drwx------  1298 root root  24K Jul 20 01:47 EH
drwx------  1298 root root  24K Jul 20 05:23 EI
drwx------  1298 root root  24K Jul 20 08:55 EJ
drwx------  1298 root root  24K Jul 20 12:31 EK
drwx------  1298 root root  24K Jul 20 16:07 EL
drwx------  1298 root root  24K Jul 20 19:43 EM
drwx------  1298 root root  24K Jul 20 23:19 EN
drwx------  1298 root root  24K Jul 21 02:54 EO
drwx------  1298 root root  24K Jul 21 06:29 EP
drwx------  1298 root root  24K Jul 21 10:02 EQ
drwx------  1298 root root  24K Jul 21 13:38 ER
drwx------  1298 root root  24K Jul 21 17:14 ES
drwx------  1298 root root  24K Jul 21 20:50 ET
drwx------  1298 root root  24K Jul 22 00:26 EU
drwx------  1298 root root  24K Jul 22 04:02 EV
drwx------  1298 root root  24K Jul 22 07:38 EW
drwx------  1298 root root  24K Jul 22 11:13 EX
drwx------  1298 root root  24K Jul 22 14:49 EY
drwx------  1298 root root  24K Jul 22 18:25 EZ
drwx------  1298 root root  24K Jul 22 22:01 F0
drwx------  1298 root root  24K Jul 23 01:37 F1
drwx------  1298 root root  24K Jul 23 05:13 F2
drwx------  1298 root root  24K Jul 23 08:49 F3
drwx------  1298 root root  24K Jul 23 12:25 F4
drwx------  1298 root root  24K Jul 23 16:01 F5
drwx------  1298 root root  24K Jul 23 19:37 F6
drwx------  1298 root root  24K Jul 23 23:13 F7
drwx------  1298 root root  24K Jul 24 02:49 F8
drwx------  1298 root root  24K Jul 24 06:25 F9
drwx------  1298 root root  24K Jul 24 09:59 FA
drwx------  1298 root root  24K Jul 24 13:35 FB
drwx------  1298 root root  24K Jul 24 17:07 FC
drwx------  1298 root root  24K Jul 24 20:43 FD
drwx------  1298 root root  24K Jul 25 00:19 FE
drwx------  1298 root root  24K Jul 25 03:54 FF
drwx------  1298 root root  24K Jul 25 07:31 FG
drwx------  1298 root root  24K Jul 25 11:07 FH
drwx------  1298 root root  24K Jul 25 14:43 FI
drwx------  1298 root root  24K Jul 25 18:18 FJ
drwx------  1298 root root  24K Jul 25 21:54 FK
drwx------  1298 root root  24K Jul 26 01:30 FL
drwx------  1298 root root  24K Jul 26 05:06 FM
drwx------  1298 root root  24K Jul 26 08:42 FN
drwx------  1298 root root  24K Jul 26 12:18 FO
drwx------  1298 root root  24K Jul 26 15:54 FP
drwx------  1298 root root  24K Jul 26 19:30 FQ
drwx------  1298 root root  24K Jul 26 23:06 FR
drwx------  1298 root root  24K Jul 27 02:42 FS
drwx------  1298 root root  24K Jul 27 06:18 FT
drwx------  1298 root root  24K Jul 27 09:50 FU
drwx------  1298 root root  24K Jul 27 13:26 FV
drwx------  1298 root root  24K Jul 27 17:02 FW
drwx------  1298 root root  24K Jul 27 20:38 FX
drwx------  1298 root root  24K Jul 28 00:14 FY
drwx------  1298 root root  24K Jul 28 03:50 FZ
drwx------  1298 root root  24K Jul 28 07:22 G0
drwx------  1298 root root  24K Jul 28 10:58 G1
drwx------  1298 root root  24K Jul 28 14:34 G2
drwx------  1298 root root  24K Jul 28 18:10 G3
drwx------  1298 root root  24K Jul 28 21:46 G4
drwx------  1298 root root  24K Jul 29 01:22 G5
drwx------  1298 root root  24K Jul 29 04:58 G6
drwx------  1298 root root  24K Jul 29 08:34 G7
drwx------  1298 root root  24K Jul 29 12:10 G8
drwx------  1298 root root  24K Jul 29 15:46 G9
drwx------  1298 root root  24K Jul 29 19:22 GA
drwx------  1298 root root  24K Jul 29 22:58 GB
drwx------  1298 root root  24K Jul 30 02:33 GC
drwx------  1298 root root  24K Jul 30 06:09 GD
drwx------  1298 root root  24K Jul 30 09:45 GE
drwx------  1298 root root  24K Jul 30 13:21 GF
drwx------  1298 root root  24K Jul 30 16:57 GG
drwx------  1298 root root  24K Jul 30 20:33 GH
drwx------  1298 root root  24K Jul 31 00:09 GI
drwx------  1298 root root  24K Jul 31 03:45 GJ
drwx------  1298 root root  24K Jul 31 07:21 GK
drwx------  1298 root root  24K Jul 31 10:57 GL
drwx------  1298 root root  24K Jul 31 14:33 GM
drwx------  1298 root root  24K Jul 31 18:04 GN
drwx------  1298 root root  24K Jul 31 21:40 GO
drwx------  1298 root root  24K Aug  1 01:16 GP
drwx------  1298 root root  24K Aug  1 04:52 GQ
drwx------  1298 root root  24K Aug  1 08:28 GR
drwx------  1298 root root  24K Aug  1 12:02 GS
drwx------  1298 root root  24K Aug  1 15:38 GT
drwx------  1298 root root  24K Aug  1 19:14 GU
drwx------  1298 root root  24K Aug  1 22:50 GV
drwx------  1298 root root  24K Aug  2 02:26 GW
drwx------  1298 root root  24K Aug  2 06:02 GX
drwx------  1298 root root  24K Aug  2 09:37 GY
drwx------  1298 root root  24K Aug  2 13:11 GZ
drwx------   451 root root 8.0K Aug  2 14:26 H0
Please do let me know what could be the best practices and checks to validate post migration activity.
Thanks, Pavan
lgute
Re: observing more disk space utilization post migration
Post by lgute »
Hi @pavan509, thanks for reaching out.
I searched the forum and had to do a bit of googling on this one.
This seems to be a good resource from unix.stackexchange.com linux - sudo: unable to mkdir /var/log/sudo-io/00/2A: No space left and this article on setting sudo configurations, may be helpful Useful Sudoers Configuring sudo Command in Linux
Here is a synopsis from the RedHat article, referenced in the unix.stackexchange post.
The sudo-io logs are filling up /var.
This can be resolved by using the maxseq directive in the /etc/sudoers file.
For example
Defaults  maxseq=1000
With this setting, only the last 1000 sudo command history will be kept. The oldest command after 1000 numbers, will be truncated by sudo-io.
A single sudo command stores its output in 7-8 files, so if there is no limitation on sudo-io event creation, it will kill all inode.
-Laura
Post Reply
