nagios on aix
srikanth.kallu
nagios on aix
How do i make sure nrpe process on aix starts after the reboot.
Please advice.
Thank You!
Please advice.
Thank You!
Re: nagios on aix
Are you having issues with NRPE not starting on reboot?
srikanth.kallu
Re: nagios on aix
Yes unfortunately this is happening with one of my server.
Re: nagios on aix
Is this the same server we were having trouble with and it was showing up inoperative?
srikanth.kallu
Re: nagios on aix
It is not he same but belongs to same group/ similar server
Re: nagios on aix
Try running:
Reboot the server and see if nrpe will start automatically.
Hope this helps.
startsrc -s nrpeHope this helps.
srikanth.kallu
Re: nagios on aix
I have just observed that this is happening with all the aix servers
Re: nagios on aix
Are these all AIX 7 (unsupported version) servers?
srikanth.kallu
Re: nagios on aix
Yes it is unsupported version but i have only one AIX 5.3 server.
Nagios is not starting on this also after the reboot.
Regarding AIX 7.1, its base is 6.1 so there sould not be any difference between them.
Please let me know if you reqiure any information from my end
Thank You!
Thank You!
Re: nagios on aix
To be completely clear, you used the NRPE AIX installer on which server, the 5.3, 7.1, or 6.1? Or all of them, just want to clear this up to get a fresh perspective.
