CPU usage on hosts
Post Reply
kickalillas2
CPU usage on hosts
Post by kickalillas2 »
I am having an issue on our windows systems in which XI reports incorrect CPU values. This is occurring on all the Windows systems I have spot checked. Our environment is a mix of 2019, 2016, and 2012R2. Our Linux hosts, RHEL 8/Centos 7, seem very close to what is reported in XI.
I first noticed this issue last week, but I can't say for certain how long or if it has always been present. However, we had a production problem yesterday where a process ended up using 100% CPU, shown via windows task manager and XI was showing between the 40%-70% range.
Our hosts are well specced so we typically don't have problems with this.
Troubleshooting steps which I've already taken... Upgrading XI to latest version. Upgrading the agent on a few test machines. I have even tried setting up an alternate monitor via SNMP and those values came back close to or the same as the NCPA agent values. I am at a loss on what else I can try here so I can only assume this is a bug that was introduced at some point. Is anyone else experiencing something similar or have any ideas that I can try?
XI Version - 2024R1.1.5
NCPA - Mix of 3.1 or 2.4
jmichaelson
Re: CPU usage on hosts
Post by jmichaelson »
By that you mean that those values matched what NCPA was reporting to your XI server? If not, how were you getting the NCPA values?
-Jason
kickalillas2
jmichaelson wrote: Tue Aug 13, 2024 1:41 pm
I apologize if not clear, but I added a second check against the host using the SNMP wizard. When I first added the SNMP check, these values looked closer, but now they are way off, so that may have been a fluke. I understand based on polling checks and response times, the reported values might vary a bit, but we are not even in the same ballpark as what is being reported on the host itself.
jmichaelson
I can't speak for how SNMP grabs its CPU utilization numbers (but even those seem low). You can see here https://github.com/NagiosEnterprises/nc ... r/psapi.py that NCPA is using the psutils CPU percent call, which defaults to checking the usage over a half-second interval:
ps.cpu_percent(interval=cpu_interval, percpu=True)
Do you by any chance have that interval turned down in the NCPA configuration? That could dramatically effect the numbers for CPU usage.
-Jason
Post Reply
