RESOLVED - Stuck at Apply Configuration Waiting for Config Verification
jkleinbard
Selected Apply Configuration
Sitting at Waiting for Configuration Verification .. Have tried using previous configuration with same result
Re: Stuck at Apply Configuration Waiting for Config Verification
Hello @jkleinbard,
Thank you for reaching out, and sorry to hear you are running into an issue with applying configurations.
What distribution and version of Nagios XI are you using?
jkleinbard
Can you post the Command Output from a recent config snapshot that is in error state? I would also suggest taking a look at your php logs. The location for these can vary by Linux distro. Possible candidates for this would be:
If you could post the contents of these logs from around the timestamp on the error-stated config snapshot along with the Command Output, that would be helpful in narrowing down the issue. In addition, letting us know your Linux distro/release would be helpful for future troubleshooting.
/var/log/httpd/error_logCode: Select all
/var/log/apache2/error.logCode: Select all
/var/log/php-fpm/www-error.log-
jkleinbard
3.10.0-1160.119.1.el7.x86_64
from error_log
[Sun Aug 11 03:46:01.603837 2024] [lbmethod_heartbeat:notice] [pid 79782] AH02282: No slotmem from mod_heartmonitor
[Sun Aug 11 03:46:01.630241 2024] [mpm_prefork:notice] [pid 79782] AH00163: Apache/2.4.6 (Red Hat Enterprise Linux) O
penSSL/1.0.2k-fips PHP/5.4.16 configured -- resuming normal operations
[Sun Aug 11 03:46:01.630253 2024] [core:notice] [pid 79782] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
The other two logs do not exist.
All configurations are tagged OK
from error_log
Try doing an apply from the shell as nagios.
/usr/local/nagiosxi/scripts/reconfigure_nagios.sh
Only one of those error log locations should exist, so that makes sense! Are you able to provide the Config Command output as well? I'm not seeing anything in your log snippet that clue me into what the issue might be. The prompt to show the Config Command should be on the Config Status column if you go to Configure > Core Config Manager > Quick Tools > Configuration Snapshots.
This is in addition to @kg2857's response which I would also definitely try.
jkleinbard
attached is reconfigure output
Have you tried restoring to a snapshot that says the response was working? If not and want to try it, make sure to take a snapshot of your vm right before so you wont lose much information if you need to revert.
jkleinbard
