Exposing/Redacting the values for User Macros is working via the global setting in NagiosXI->Administration so there is a workaround.
NagiosXI 2024R1.2 | CCM Unable to enable/disable redact macro values
Working through setting up testing R1.2 on Ubuntu24.04LTS
and noticed that I was unable to enable/disable display redacted values in CCM using the nifty little checkbox
betterwound
Re: NagiosXI 2024R1.2 | CCM Unable to enable/disable redact macro values
I don't think that's a good trickeggy car
