Licensing - Stand up a new server for upgrade
This support forum board is for questions relating to Nagios Fusion.
Post Reply
NeoMatrixJR
Post by NeoMatrixJR »
We'd like to start looking into standing up a 2nd server to migrate to with the latest version of Fusion on a new OS. I'm not sure how the Fusion license works. Are we only licensed for our one prod instance or do we have any Dev/DR licensing as well? Is there any option for a "trial" license or temporary license if not so we can stand up and migrate to a new system?
lgute
Re: Licensing - Stand up a new server for upgrade
Post by lgute »
Hi @NeoMatrixJR, thanks for reaching out.
When you buy a Fusion license, it comes with 3 entitlements. This allows you to stand up a production server, a backup server and a lab/test server. This is the documentation for the Fusion License Entitlements.
Since you just have the one production server, you should be good to go.
If you do have problems getting your second server entitled, please contact Customer Service at https://answerhub.nagios.com/support/s/ and they can help you straighten things out.
If you have non-technical questions about licensing, you can reach out to [email protected].
-Laura
NeoMatrixJR
Is there any way to copy the config or bulk-fuse all the servers from our existing instance to a DR or test instance?
ajcoil
Post by ajcoil »
Hello @NeoMatrixJR,
Thanks for reaching out!
Currently, there is no way to copy the config or bulk-fuse all the servers from an existing machine via the browser.
However, there are API endpoints that could prove useful in accomplishing what you need.
You can find the details to the API in Fusion by navigating to Help -> REST API Docs -> System Reference
I will submit a feature request for this as well!
If you have any other questions, comments, or concerns, feel free to reach out!
Post Reply
