Room temperature alert
Post Reply
mandar18
Post by mandar18 »
Hello Team,
Need to set a room temperature alert for my server room, I don't know which plugin needs to be installed, I am using the following devices Ubibot GS1-AETH1RS + TH30S-B Ethernet Thermometer Hygrometer, WiFi Temperature Humidity Sensor, Digital Temperature Data Logger.
It is a cloud-based device, so we don’t have an IP address to query. You will need to use the URL to find something that can read the results of an API call.
Can you please help me out?
Do I need to make changes in the command file also?
Note-We won't be having IP address only the link we will be having
bbahn
Re: Room temperature alert
Post by bbahn »
Hello @mandar18,
It sounds like you're looking for a custom plugin that will query your URL and read the response. Is this correct?
I would suggest creating a script that uses Python, Bash or some other language compatible with your Nagios Core instance that will query the desired URL and based on the response, give the appropriate output.
Here are some resources to help you get started:
Nagios Plugins - Developer Guidelines
Nagios Plugins - Developer Guidelines - Plugin Outputs
mandar18
Post by mandar18 »
But by URL, can we monitor the room's temperature using the plugin?
Also can we fetch results from API?
I want to monitor the "https://webapi.ubibot.com/channels/8933 ... b547f13f39" this link.
kg2857
Post by kg2857 »
Ask yourself how you would pull this info from the shell. Then do it. Then create a small script that does it and returns text and a return value.
Of course someone else has possibly done the same thing so check out the exchange.
mandar18
Post by mandar18 »
@Bbahn can you please help on this?
I am not getting the exact path what you are saying.
bbahn
Post by bbahn »
Hello @mandar18,
I threw together a quick python script to get you started:
import requests
import json
def get_data():
    url = "https://webapi.ubibot.com/channels/89336?account_key=7bc1cdc6599832d23e4214b547f13f39"
    response = requests.get(url)
    data = response.json()
    return data
data = get_data()
# "field1": "Temperature",
# "field2": "Humidity",
# "field3": "Voltage",
# "field4": "WIFI RSSI",
# "field5": "GSM RSSI",
# "field6": "Light",
# "field7": "RS485 Temperature",
# "field8": "RS485 Humidity",
# "field9": "RS485 Soil Temperature",
# "field10": "RS485 Soil Moisture",
# "field11": "External Light",
# "field12": "PT100 Temperature",
# "field13": "Wind Speed",
# "field14": "Carbon Dioxide",
# "field15": "RS485 Atmospheric Pressure",
def parse_data(data):
    last_values = data["channel"]['last_values']
    last_values = json.loads(last_values)
    field1 = last_values['field1']['value']
    field2 = last_values['field2']['value']
    field3 = last_values['field3']['value']
    field6 = last_values['field6']['value']
    return field1, field2, field3, field6
field1, field2, field3, field6 = parse_data(data)
print("Temperature: ", field1)
print("Humidity: ", field2)
print("Voltage: ", field3)
print("Light: ", field6)
print()
Now you just need to take this data, handle the intervals and output status. You can reference other Nagios python plugins as reference as well as use the documentation I mentioned before.
mandar18
Post by mandar18 »
Thank you Bbahan,
I need to add the host first to get data, but like I said before, I only have an API link where I can get the data.
what needs to be done now to add the same as a host in Nagios core?
For example, I am using the below stuff to add a host
use generic-host
host_name XXXX
alias XXX
address 192.168.XX.XX
max_check_attempts 5
notification_interval 60
notification_period 24x7
notification_options d,u,r
contact_groups admins
To Add the API If I don't have an IP Address then how do I add that API to the host?
mandar18
Post by mandar18 »
@Bbahan,
Can you please help me ?
bbahn
Post by bbahn »
You will want command and host or service definitions to be something like the following:
	name		        check_temperature
	command_name		check_temperature
	command_line	        $USER1$/check_temperature -I $HOSTADDRESS$ $ARG1$
	use		  	generic-service		; Inherit default values from a template
	host_name		Ubibot GS1-AETH1RS
	service_description	Temperature
	check_command		check_temperature
Where check_temperature is the name of your plugin located in /user/local/nagios/libexec
You can find out more about Nagios Core definitions here: Nagios Core Documentation - Object Definitions
Post Reply
