NagiosXI - install on new OS or OVA install
Post Reply
krw
Post by krw »
Have been using NagiosXI for quite a number of years.
Decided to update from 5.11.3 to latest as we just renewed support, but RedHat 7.9 is EOL for it.
In updating its just been to wget the upgrade.sh script and go from there for a long while.
If we deploy a new XI using the OVA is the upgrade procedure the same?
I'm sorta over spinning up a new VM, installing packages then installing XI, I will if needed, but is
the OVA file up to date on all things NagiosXI?
Thanks.
sgardil
Re: NagiosXI - install on new OS or OVA install
Post by sgardil »
krw wrote: Wed Aug 21, 2024 3:47 pm Have been using NagiosXI for quite a number of years.
Thanks.
Hey @krw
We do have an up to date OVA for each of our releases. For upgrading with the OVA, the procedure will be the same way as done before (via getting the new tar ball and running the upgrade script or upgrading via the gui). If you have any further questions please feel free to reach out.
Post Reply
