RESOLVED: Interface Status fails
sawdusty
Post by sawdusty »
I just rebuilt my Nagios XI server and have re-entered all my devices. On all my network devices, for every interface that I'm monitoring the status check is failing. The error message states the following:
(No output on stdout) stderr: execvp (usr/local/nagios/libexec/check_ifoperstatnag_by_variable, ...) failed. errno is 2: No such file or directory
I checked the folder and confirmed there is not a "check_ifoperstatnag_by_variable" script, but there is a 'check_ifoperstatnag' script. Where can I download this script?
ssunga
Re: Interface Status fails
Post by ssunga »
Hey @sawdusty,
I am not aware of a `check_ifoperstatnag_by_variable` script - if you use the `check_ifoperstatnag` script, do you get the expected output? Is this script available in your previous Nagios XI server, and if so would you be able to move it into the new server?
lgute
Post by lgute »
Hi @sawdusty, thanks for reaching out.
The plugin check_if_operstatnag_by_variable is a part of the Switch Wizard. You can copy it to libexec, as follows.
cd /usr/local/nagios/libexec
/usr/local/nagiosxi/html/includes/configwizards/switch/plugins/check_if_operstatnag_by_variable .
You may need to adjust the file ownership and permissions.
chown apache:nagios check_if_operstatnag_by_variable
chmod 775 check_if_operstatnag_by_variable
I am checking into why it is not getting installed into libexec by default.
-Laura
sawdusty
Post by sawdusty »
lgute wrote: Mon Aug 26, 2024 12:56 pm Hi @sawdusty, thanks for reaching out.
Thanks, this worked. Slight change to file ownership, my user was www-data versus apache.
lgute
Post by lgute »
Hi @sawdusty,
Thanks for letting us know what worked for you!
-Laura
