Hello everyone,
I would like to disable check Google Updater ,
I used "exclude=GoogleUpdaterVERSION" in nsclient file , but I receive new alerts when the version is modified ,
disable check google updater
- nagios.PNG (4.93 KiB) Viewed 6073 times
gwesterman
Re: disable check google updater
Hi @ouss,
It looks like some people found a working solution in this thread. Let us know if that works for you.
Thank you!
Thank you!
Thank you,
But it's not working
gwesterman
What exactly did you try and what was the output?
