Problems with XI displaying 4x duplicate services and hosts
btmikkelsen
ever since the upgrade to 2011R3.3, nagiosXI shows each service and host 4 times. Occasionally after an apply configuration it goes back to normal, but it has consistently done this since the upgrade. naigos core does NOT do this. viewing the operational files, the status.dat, retentionl.dat, etc are all what you would expect - no duplicates.
ideas?
For all support requests, we need to know:
CentOS release 5.8 (Final)
32 or 64bit? 64 bit
VMware Image or Manual Install of XI? Manual
no Gnome, no proxy, no ssl.
ideas?
32 or 64bit? 64 bit
Re: Problems with XI displaying 4x duplicate services and ho
Run the following command and post the output:
tail /var/log/messagesBe sure to check out our Knowledgebase for helpful articles and solutions!
btmikkelsen
is there anything you're looking at? This production monitoring system is doing a bunch of tasks. for instance...a tail of the message file will get you lots of non-applicable stuff. Regardless...here is a tail of /var/log/messages.
Sep 27 15:19:39 X snmpd[5862]: Connection from UDP: [127.0.0.1]:16864
Sep 27 15:19:39 X snmpd[5862]: Connection from UDP: [X]:12831
Sep 27 15:19:39 X snmpd[5862]: Connection from UDP: [X]:16864
Try running the following:
service nagios stop
killall -9 nagios
service ndo2db stop
service ndo2db start
service nagios start-
btmikkelsen
We've been living with this for quite a while now. Here is some additional information:
1) Services, not hosts duplicate 4x
2) this only happens when an "apply configuration" is performed
3) when you killall -9 nagios the service restart, the XI counters are correct
4) nagios core (/nagios) is not affected by this
5) notifications are not affected
6) retention and status files do not have 4x entries
this seems to be a XI ui issue only. Any assistance would be appreciated.
we have upgraded since this started happening:
Nagios XI Version : 2012R1.6
XX 2.6.18-348.1.1.el5 x86_64
CentOS release 5.9 (Final)
Gnome is not installed
Apache Information
PHP Version: 5.1.6
Agent: Mozilla/5.0 (Windows NT 6.2; WOW64) AppleWebKit/537.17 (KHTML, like Gecko) Chrome/24.0.1312.57 Safari/537.17
Server Name: XX
Server Address: XX
Server Port: 80
Date/Time
PHP Timezone: America/Los_Angeles
PHP Time: Tue, 26 Feb 2013 08:11:02 -0800
System Time: Tue, 26 Feb 2013 08:11:02 -0800
Nagios XI Data
nagios (pid 17667) is running...
NPCD running (pid 10989).
ndo2db (pid 27329) is running...
CPU Load 15: 3.43
Total Hosts: 2556
Total Services: 18732
Function 'get_base_uri' returns: http://XX/nagiosxi/
Function 'get_base_url' returns: http://XX/nagiosxi/
Function 'get_backend_url(internal_call=false)' returns: http://XX/nagiosxi/includes/components/ ... rofile.php
Function 'get_backend_url(internal_call=true)' returns: http://localhost/nagiosxi/backend/
Ping Test localhost
Running:
/bin/ping -c 3 localhost 2>&1
PING localhost.localdomain (127.0.0.1) 56(84) bytes of data.
64 bytes from localhost.localdomain (127.0.0.1): icmp_seq=1 ttl=64 time=0.025 ms
64 bytes from localhost.localdomain (127.0.0.1): icmp_seq=2 ttl=64 time=0.021 ms
64 bytes from localhost.localdomain (127.0.0.1): icmp_seq=3 ttl=64 time=0.024 ms
--- localhost.localdomain ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2000ms
rtt min/avg/max/mdev = 0.021/0.023/0.025/0.004 ms
Test wget To locahost
WGET From URL: http://localhost/nagiosql/index.php
Running:
/usr/bin/wget http://localhost/nagiosql/index.php
--2013-02-26 08:11:04-- http://localhost/nagiosql/index.php
Resolving localhost... 127.0.0.1
Connecting to localhost|127.0.0.1|:80... connected.
Length: 5259 (5.1K) [text/html]
Saving to: `/tmp/nagiosql_index.tmp'
0K ..... 100% 313M=0s
2013-02-26 08:11:04 (313 MB/s) - `/tmp/nagiosql_index.tmp' saved [5259/5259]
Apache Information
PHP Version: 5.1.6
Server Name: XX
Server Address: XX
Server Port: 80
Date/Time
Nagios XI Data
CPU Load 15: 3.43
Total Hosts: 2556
Ping Test localhost
Running:
Running:
After you apply configuration and these duplicates appear how long does it take before they..disappear? Can you provide a screenshot of this as it happens? I'm also curious to see how many processes are running when this happens. Next time it does can you run the following command and post the output with the screenshot of your UI?:
Also, how many checks is your system running on average per minute? And what is the load on the system.
ps -ef|grep bin/nagios | grep -v grep-
btmikkelsen
after applying the configuration, duplicates happen as soon as XI starts displaying status again. these ghost services will only go away by killing the nagios processes and restarting. (killall -9 nagios; service nagios restart).
this is very easy to duplicate - it is just a matter of applying the configuration. Again - nagios core is unaffected, so these ghost host and services must only be present in the XI ui.
Attached is a screenshot of the tactical showing both.
nagios 4589 1 16 16:05 ? 00:00:01 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
FYI: http://<serveraddress>/nagiosxi/backend/?cmd=getservicestatus sometimes times out, depending on the load at the time. I don't know if this is related, or not - it is listed in the troubleshooting steps when the count is incorrect? XI Display Problems.
Do you get any errors or notices in the /usr/local/nagios/var/nagios.log file when you run:
Also, lets try the following:
This will start nagios with everything in a pending state, but should give somewhat of a clean reset.
Can you also post your /usr/local/nagios/etc/nagios.cfg file?
service nagios restartAlso, lets try the following:
service nagios stop
rm -f /usr/local/nagios/var/retention.dat
service nagios startCan you also post your /usr/local/nagios/etc/nagios.cfg file?
btmikkelsen
I tried these steps, without change.
nagios.cfg
nagios.cfg
# MODIFIED
[email protected]
[email protected]
translate_passive_host_checks=1
log_event_handlers=0
use_large_installation_tweaks=1
enable_environment_macros=0
#debug_level=-1
# all but function enter/exit
debug_level=126
# NDOUtils module
broker_module=/usr/local/nagios/bin/ndomod.o config_file=/usr/local/nagios/etc/ndomod.cfg
# PNP settings - bulk mode with NCPD
process_performance_data=1
# service performance data
service_perfdata_file=/var/nagiosramdisk/service-perfdata
service_perfdata_file_template=DATATYPE::SERVICEPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tSERVICEDESC::$SERVICEDESC$\tSERVICEPERFDATA::$SERVICEPERFDATA$\tSERVICECHECKCOMMAND::$SERVICECHECKCOMMAND$\tHOSTSTATE::$HOSTSTATE$\tHOSTSTATETYPE::$HOSTSTATETYPE$\tSERVICESTATE::$SERVICESTATE$\tSERVICESTATETYPE::$SERVICESTATETYPE$\tSERVICEOUTPUT::$SERVICEOUTPUT$
service_perfdata_file_mode=a
service_perfdata_file_processing_interval=15
#service_perfdata_file_processing_command=process-service-perfdata-file-bulk
service_perfdata_file_processing_command=process-service-perfdata-file-pnp-bulk
# host performance data
host_perfdata_file=/var/nagiosramdisk/host-perfdata
host_perfdata_file_template=DATATYPE::HOSTPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tHOSTPERFDATA::$HOSTPERFDATA$\tHOSTCHECKCOMMAND::$HOSTCHECKCOMMAND$\tHOSTSTATE::$HOSTSTATE$\tHOSTSTATETYPE::$HOSTSTATETYPE$\tHOSTOUTPUT::$HOSTOUTPUT$
host_perfdata_file_mode=a
host_perfdata_file_processing_interval=15
#host_perfdata_file_processing_command=process-host-perfdata-file-bulk
host_perfdata_file_processing_command=process-host-perfdata-file-pnp-bulk
# OBJECTS - UNMODIFIED
#cfg_file=/usr/local/nagios/etc/objects/commands.cfg
#cfg_file=/usr/local/nagios/etc/objects/contacts.cfg
#cfg_file=/usr/local/nagios/etc/objects/localhost.cfg
#cfg_file=/usr/local/nagios/etc/objects/templates.cfg
#cfg_file=/usr/local/nagios/etc/objects/timeperiods.cfg
# STATIC OBJECT DEFINITIONS (THESE DON'T GET EXPORTED/IMPORTED BY NAGIOSQL)
cfg_dir=/usr/local/nagios/etc/static
# OBJECTS EXPORTED FROM NAGIOSQL
cfg_file=/usr/local/nagios/etc/contacttemplates.cfg
cfg_file=/usr/local/nagios/etc/contactgroups.cfg
cfg_file=/usr/local/nagios/etc/contacts.cfg
cfg_file=/usr/local/nagios/etc/timeperiods.cfg
cfg_file=/usr/local/nagios/etc/commands.cfg
cfg_file=/usr/local/nagios/etc/hostgroups.cfg
cfg_file=/usr/local/nagios/etc/servicegroups.cfg
cfg_file=/usr/local/nagios/etc/hosttemplates.cfg
cfg_file=/usr/local/nagios/etc/servicetemplates.cfg
cfg_file=/usr/local/nagios/etc/servicedependencies.cfg
cfg_file=/usr/local/nagios/etc/serviceescalations.cfg
cfg_file=/usr/local/nagios/etc/hostdependencies.cfg
cfg_file=/usr/local/nagios/etc/hostescalations.cfg
cfg_file=/usr/local/nagios/etc/hostextinfo.cfg
cfg_file=/usr/local/nagios/etc/serviceextinfo.cfg
cfg_dir=/usr/local/nagios/etc/hosts
cfg_dir=/usr/local/nagios/etc/services
# Viad Service dependencies
cfg_file=/usr/local/nagios/etc/viad_servicedependencies.cfg
# GLOBAL EVENT HANDLERS
global_host_event_handler=xi_host_event_handler
global_service_event_handler=xi_service_event_handler
# UNMODIFIED
accept_passive_host_checks=1
additional_freshness_latency=15
auto_reschedule_checks=0
auto_rescheduling_interval=30
auto_rescheduling_window=180
bare_update_check=0
cached_host_check_horizon=15
cached_service_check_horizon=15
check_external_commands=1
check_for_orphaned_hosts=1
check_for_orphaned_services=1
check_for_updates=1
check_host_freshness=0
check_result_path=/var/nagiosramdisk/spool/checkresults
#check_result_reaper_frequency=10
check_service_freshness=1
command_check_interval=-1
command_file=/usr/local/nagios/var/rw/nagios.cmd
daemon_dumps_core=0
date_format=us
debug_file=/var/nagiosramdisk/nagios.debug
debug_verbosity=1
enable_embedded_perl=0
enable_event_handlers=1
enable_flap_detection=1
enable_notifications=1
event_broker_options=-1
event_handler_timeout=30
execute_host_checks=1
execute_service_checks=1
external_command_buffer_slots=4096
high_host_flap_threshold=20.0
host_check_timeout=30
interval_length=60
lock_file=/usr/local/nagios/var/nagios.lock
log_external_commands=0
log_file=/var/nagiosramdisk/nagios.log
log_host_retries=1
log_initial_states=0
log_notifications=1
log_passive_checks=0
log_rotation_method=d
log_service_retries=1
low_host_flap_threshold=5.0
#max_check_result_reaper_time=30
max_check_result_reaper_time=40
max_concurrent_checks=0
max_debug_file_size=100000000
max_host_check_spread=30
max_service_check_spread=20
nagios_group=nagios
nagios_user=nagios
notification_timeout=30
#object_cache_file=/usr/local/nagios/var/objects.cache
object_cache_file=/var/nagiosramdisk/objects.cache
obsess_over_hosts=0
obsess_over_services=0
ocsp_timeout=5
p1_file=/usr/local/nagios/bin/p1.pl
perfdata_timeout=5
#precached_object_file=/usr/local/nagios/var/objects.precache
precached_object_file=/var/nagiosramdisk/objects.precache
resource_file=/usr/local/nagios/etc/resource.cfg
retain_state_information=1
retention_update_interval=60
service_check_timeout=90
service_interleave_factor=s
sleep_time=0.25
soft_state_dependencies=0
state_retention_file=/usr/local/nagios/var/retention.dat
status_file=/usr/local/nagios/var/status.dat
#status_file=/var/nagiosramdisk/status.dat
status_update_interval=10
temp_file=/usr/local/nagios/var/nagios.tmp
temp_path=/var/nagiosramdisk/tmp
use_embedded_perl_implicitly=0
use_regexp_matching=0
use_retained_program_state=1
use_syslog=1
use_true_regexp_matching=0
Reason: Please use [code][/code] tags for large amounts of text.
Can you run the DB repair procedure? Lets make sure there's not any DB corruption so we can rule that out.
http://assets.nagios.com/downloads/nagi ... tabase.pdf
