Issue with Core server installation
miniman321
Post by miniman321 »
Hello guys,
once I am trying to initiate nagios installation on Debian 12, and performing configuration check, I am getting this error:
checking for SSL headers... configure: error: Cannot find ssl headers
based on this I am not able to initiate installation as I cannot execute make cmdlet
make: *** No targets specified and no makefile found. Stop.
Could you please help me with this?
Many thanks in advance for your help!
miniman321
Re: Issue with Core server installation
Anyone would be able to help please? Or maybe point to some relevant resource? I am kinda stucked at this very moment with implementation.
Many thanks!
gwesterman
Post by gwesterman »
Hi @miniman321,
Try manually installing the ssl package.
apt clean
apt update
apt upgrade
apt install openssl
Then try to install core.
Let us know if this works or not and if you have any additional questions.
Thank you!
miniman321
Yes I found this as a solution before your post, and it worked!
Many thanks for your help!
gwesterman
Glad you found your solution!
Please reach out if you have any other questions.
I'm gonna lock this thread.
