Return code 13 is out of bounds - check_ncpa
Post Reply
crispy
Post by crispy »
Having moved my nagios installation to a new server I was receiving the above status information for all service checks on my single Windows machine. After much reading of other threads (and a successful attempt using the tool from the command line) I discovered, partly by accident, that the issue was permissions/ownership on the /usr/local/nagios/libexec/check_ncpa.py file.
To fix I ran the following:
sudo chown nagios:nagios /usr/local/nagios/libexec/check_ncpa.py
sudo chmod 750 /usr/local/nagios/libexec/check_ncpa.py
No need for a restart as nagios will continue to attempt to execute this file just as before, only now it will be allowed to.
nagios-mikep97
Re: Return code 13 is out of bounds - check_ncpa
Post by nagios-mikep97 »
I am having the same issue, return code 13, and tried those fixes you mentioned with no luck. I also am able to run check_ncpa.py as the nagios user successfully.
One other note, my plugins directory is located here.
/usr/lib64/nagios/plugins/
Any more ideas ?
thanks, mp
bbahn
Post by bbahn »
Hello @nagios-mikep97,
Have you tried running check_ncpa.py in verbose mode when testing? By adding -v, you can get more information about what's going wrong. Try running it with -v and post the output here (redacting any potentially sensitive information, of course).
The location of your plugin won't have any effect on the output of check_ncpa.py, so you don't need to worry about that.
nagios-mikep97
@bbahn,
I posted in the other thread. Thanks so much.
Post Reply
