I can't seem to get Linux machines running NCPA to pull a list of available plugins.
Windows is working but not linux. Is this a known issue or do I have something else going on?
Linux NCPA Wizard doesn't populate Plugins like on Windows
Prod XI: Debian 12 - Nagios XI 2024R2.1
Dev XI: Debian 12 - Nagios XI 2026R1
Re: Linux NCPA Wizard doesn't populate Plugins like on Windows
GldRush98,
It seems like something else is likely going on. I just spun up an NCPA agent to test this on a RHEL 8 system and I was able to see the plugins located at:
Seems like a silly question, but have you confirmed that you have executable plugins in the aforementioned directory on the server you are trying to monitor?
Best Regards,
Cory Norell
/usr/local/ncpa/plugins/Seems like a silly question, but have you confirmed that you have executable plugins in the aforementioned directory on the server you are trying to monitor?
Best Regards,
Cory Norell
Hi GldRush98,
I wanted to add onto Cory's info -- Is the highlighted element in the screenshot I attached what you're having issues with? If so, this is a known issue and is fixed in the upcoming release for XI.
I'm sorry for the confusion. I don't know what happened that day, but everything is working fine when I checked on it today. You can close this one.
gwesterman
Glad it resolved itself.
Locking.
Locking.
