RESOLVED: Download Older Version of Nagios XI
JohnFLi
Post by JohnFLi »
I am currently running 2024R1.1.2
I cannot upgrade to 2024R1.2.1 due to running CentOS 7
M y plan is to create a new machine, install my current XI on it. Backup my current XI, restore it to the new machine, then upgrade to the newest version of XI.
to do that, I would need to install 2024R1.1.2 on the new machine first, correct?
So how can i get 2024R1.2.1?
kg2857
Re: Download Older Version of Nagios XI
Post by kg2857 »
You can. You might need to search to find the page.
gregbeyer
Post by gregbeyer »
All Nagios versions are available on repo.nagios.com Your CentOS ones are in here -- https://repo.nagios.com/?repo=rpm-centos
sgardil
Post by sgardil »
If you dont want to do a RPM install you can use this site to get old tarballs for NagiosXI.
https://assets.nagios.com/downloads/nag ... rsions.php
JohnFLi
Post by JohnFLi »
great, thank both of you
This issue scan be closed
Everybody is somebody else’s weirdo
lgute
Post by lgute »
Marking this issue "Resolved"
-Laura
