Deploy agent wizard in Nagios XI not work correctly after restore
Post Reply
zoomint
Post by zoomint »
we have performed Nagios XI migration from 2024R1.1.5 on CentOS 8 Stream to Ubuntu LTS 22 and afterwards upgraded Nagios XI to 2024R1.2.1.
Almost everything is working correctly, we have also used https://assets.nagios.com/downloads/nag ... _repair.sh script post upgrade to fix everything as it was platform migration, but Deploy Agent is not working correctly
It looks wizard deploy NCPA on linux servers, but jobs never ends in UI, but in "Past jobs" is marked as completed. When opening this past job, getting error 500 in browser devtools console. In apache2 error log is error from PHP. all in screenshots below.
How can this be troubleshooted?
jsimon
Re: Deploy agent wizard in Nagios XI not work correctly after restore
Post by jsimon »
Hi @zoomint,
This is a known bug in version 2024R1.2.1. We have corrected this in the next release, which should be upcoming. I don't have an exact date for you but look for that issue to be fixed when the next upgrade is available.
Post Reply
