nagios 4.5.4 on fedora Install Issue
Post Reply
kcrowl
Post by kcrowl »
Hello all i have a question regarding an issue while installing nagios core on fedora server when i go to try and make install or installing the webconf even i get the make error no rule to makefile and im not sure how to rectify the issue.
bbahn
Re: nagios 4.5.4 on fedora Install Issue
Post by bbahn »
Hello @kcrowl,
Can you explain more clearly and in detail what the issue you are encountering is?
Were you following this: Nagios Core - Installing Nagios Core From Source?
At which stage in this process did you run into the error?
What is the exact error you encountered?
Post Reply
