Hello!! I can´t add a CA certificate for to configure LDAP SSL. When try, error is "This certificate already exists"
I've NagiosXI v 5.10.0
I tried
chown -R apache.nagios /usr/local/nagiosxi/var/certs
and
chmod 777 /usr/local/nagiosxi/var/certs
I'm using SSL whith GUI and its OK
LDAP SSL Existing Certificate
Re: LDAP SSL Existing Certificate
Hello @bergna,
Thank you for reaching out!
I have a few questions to better understand your situation:
1. What distribution are you running Nagios XI on?
2. Do you have any existing certs in the following directory?
/etc/openldap/certsRe: LDAP SSL Existing Certificate
Hello @ajcoil
I'm running Nagios on a
CentOS Linux release 7.9.2009 (Core)
And in /etc/openldap/certs
-rw-r--r--. 1 root root 65536 Jul 11 2019 cert8.db
-rw-r--r--. 1 root root 16384 Jul 11 2019 key3.db
-r--------. 1 root root 45 Jul 11 2019 password
-rw-r--r--. 1 root root 16384 Jul 11 2019 secmod.db
certificates for SSL GUI are in /usr/local/nagiosxi/var/certs/
Thanks in advance
Thanks in advance
Can you run this command and see if the cert you are trying to add is already there?bergna wrote: ↑Fri Sep 20, 2024 12:55 pm Hello @ajcoil
Thanks in advance
ls -l /usr/local/nagiosxi/var/certs/
The error given doesnt sound like a permissions issue. It could be a caching issue if you don't have the certificate already made in that file. Also check to see who owns the file if it does exist in that directory.
