Unable to Start Monitoring Engine Process
GreatWolfResorts
Post by GreatWolfResorts »
Our Monitoring Engine Process state is currently stopped, and I am unable to get it to restart. All other XI System components were in a start state until we attempt to start it from the web interface. After the attempt, I watch components listed from command subsystem on down going into alert status:
- command Subsystem
- Event Manager
- Feed Processor
- Report Engine
- System statistics
All slowly moved to the alert state.
We just recently upgraded to version 2011R3.3. I'm not even sure where to begin here.
Nagios XI 5.2.5 | CentOS6.3 x86_64 | Virtual Instance on VMware vSphere 6
mguthrie
Re: Unable to Start Monitoring Engine Process
Post by mguthrie »
Check your free disk space just to make sure the drive isn't full.
Also try the following commands and post if you get any error output:
service crond restart
service nagios restart
Are you getting and revealing errors from /var/log/messages?
GreatWolfResorts
Ran a "df -h" and it looks like we're not even 50% use on the disks. Restarted both the crond and nagios service and looks like we're good to go. I had restarted the nagios service previously, but I never thought about hitting crond.
Thanks for your help!
mguthrie
Post by mguthrie »
Good deal. If you see any other odd behavior go ahead and let us know!
