NagiosXI API v2 | Host Status 1 vs. Many query results
Post Reply
snapier3
Post by snapier3 »
I don't know if this is the place but, here it goes.
While familiarizing myself with v2 of the API I noticed that there is an issue when a single item is returned for the host & service class of the status endpoint.
Here's an example python using a limited query to isolate localhost and return only one result.
#VARS FOR API
myxi = "192.168.1.1"
myep = "status"
mycls = "host"
qry = "&name=localhost"
mytkn = "auth_token" #provided by nagiosxi api
#NAGIOSXI API V2
def api2(myxi,myep,mycls,qry,mytkn):
    try:
        myurl = "https://{}/nagiosxi/api/v2/{}/{}?{}&token={}".format(myxi,myep,mycls,qry,mytkn)
        #GET RESULTS
        response = requests.get(myurl, verify=False)
        r = response.json()
    except Exception as e:
        r = e
    finally:
        return r
Results are returned but... not exactly what I expected. I got strings?!
HOSTCOUNT=1
<class 'str'>
@attributes2
<class 'str'>
instance_id
<class 'str'>
host_id
<class 'str'>
name
<class 'str'>
display_name
<class 'str'>
address
<class 'str'>
alias
<class 'str'>
status_update_time
<class 'str'>
status_text
<class 'str'>
status_text_long
<class 'str'>
current_state
<class 'str'>
icon_image
<class 'str'>
icon_image_alt
<class 'str'>
performance_data
<class 'str'>
should_be_scheduled
<class 'str'>
check_type
<class 'str'>
last_state_change
<class 'str'>
last_hard_state_change
<class 'str'>
last_hard_state
<class 'str'>
last_time_up
<class 'str'>
last_time_down
<class 'str'>
last_time_unreachable
<class 'str'>
last_notification
<class 'str'>
next_notification
<class 'str'>
no_more_notifications
<class 'str'>
acknowledgement_type
<class 'str'>
current_notification_number
<class 'str'>
event_handler_enabled
<class 'str'>
process_performance_data
<class 'str'>
obsess_over_host
<class 'str'>
modified_host_attributes
<class 'str'>
event_handler
<class 'str'>
check_command
<class 'str'>
normal_check_interval
<class 'str'>
retry_check_interval
<class 'str'>
check_timeperiod_id
<class 'str'>
has_been_checked
<class 'str'>
current_check_attempt
<class 'str'>
max_check_attempts
<class 'str'>
last_check
<class 'str'>
next_check
<class 'str'>
state_type
<class 'str'>
notifications_enabled
<class 'str'>
problem_acknowledged
<class 'str'>
passive_checks_enabled
<class 'str'>
active_checks_enabled
<class 'str'>
flap_detection_enabled
<class 'str'>
is_flapping
<class 'str'>
percent_state_change
<class 'str'>
latency
<class 'str'>
execution_time
<class 'str'>
scheduled_downtime_depth
<class 'str'>
notes
<class 'str'>
notes_url
<class 'str'>
action_url
Now if the query is formatted to return 2 or more hosts/services, we get something that looks more usable.
Using the same example from above but, passing in a query to isolate two hosts.
qry = "&name=in:localhost,u2204ncpa"
HOSTCOUNT=2
<class 'dict'>
{'@attributes': {'id': '3'}, 'instance_id': '1', 'host_id': '205', 'name': 'u2204ncpa', 'display_name': 'u2204ncpa', 'address': '192.168.1.136', 'alias': 'linux-columbia-mo', 'status_update_time': '2024-09-26 16:30:36', 'status_text': 'Server is Up', 'status_text_long': {}, 'current_state': '0', 'icon_image': 'ubuntu.png', 'icon_image_alt': {}, 'performance_data': {}, 'should_be_scheduled': '1', 'check_type': '1', 'last_state_change': '2024-09-25 18:56:48', 'last_hard_state_change': '2024-09-25 18:56:48', 'last_hard_state': '0', 'last_time_up': '2024-09-23 19:03:50', 'last_time_down': '2024-09-25 18:56:48', 'last_time_unreachable': '1970-01-01 00:00:00', 'last_notification': '2024-09-25 18:56:48', 'next_notification': '1970-01-01 00:00:00', 'no_more_notifications': '0', 'acknowledgement_type': '0', 'current_notification_number': '0', 'event_handler_enabled': '1', 'process_performance_data': '1', 'obsess_over_host': '1', 'modified_host_attributes': '1', 'event_handler': {}, 'check_command': {}, 'normal_check_interval': '5', 'retry_check_interval': '3', 'check_timeperiod_id': '173', 'has_been_checked': '1', 'current_check_attempt': '1', 'max_check_attempts': '2', 'last_check': '2024-09-25 18:56:48', 'next_check': '2024-09-26 16:35:36', 'state_type': '1', 'notifications_enabled': '1', 'problem_acknowledged': '0', 'passive_checks_enabled': '1', 'active_checks_enabled': '1', 'flap_detection_enabled': '1', 'is_flapping': '0', 'percent_state_change': '0', 'latency': '0.0031169999856501818', 'execution_time': '0', 'scheduled_downtime_depth': '0', 'notes': 'ht-linux-columbia-mo (38.95171,-92.33407)', 'notes_url': {}, 'action_url': {}}
<class 'dict'>
{'@attributes': {'id': '1'}, 'instance_id': '1', 'host_id': '178', 'name': 'localhost', 'display_name': 'localhost', 'address': '127.0.0.1', 'alias': 'localhost', 'status_update_time': '2024-09-26 16:30:51', 'status_text': 'OK - 127.0.0.1: rta 0.018ms lost 0%', 'status_text_long': {}, 'current_state': '0', 'icon_image': {}, 'icon_image_alt': {}, 'performance_data': 'rta=0.018ms;3000.000;5000.000;0; pl=0%;80;100;0;100 rtmax=0.036ms;;;; rtmin=0.013ms;;;;', 'should_be_scheduled': '1', 'check_type': '0', 'last_state_change': '2024-08-14 05:07:28', 'last_hard_state_change': '2024-08-14 05:07:28', 'last_hard_state': '0', 'last_time_up': '2024-09-26 16:30:51', 'last_time_down': '1970-01-01 00:00:00', 'last_time_unreachable': '1970-01-01 00:00:00', 'last_notification': '1970-01-01 00:00:00', 'next_notification': '1970-01-01 00:00:00', 'no_more_notifications': '0', 'acknowledgement_type': '0', 'current_notification_number': '0', 'event_handler_enabled': '1', 'process_performance_data': '1', 'obsess_over_host': '1', 'modified_host_attributes': '0', 'event_handler': {}, 'check_command': 'check-host-alive', 'normal_check_interval': '5', 'retry_check_interval': '1', 'check_timeperiod_id': '167', 'has_been_checked': '1', 'current_check_attempt': '1', 'max_check_attempts': '10', 'last_check': '2024-09-26 16:30:51', 'next_check': '2024-09-26 16:35:51', 'state_type': '1', 'notifications_enabled': '1', 'problem_acknowledged': '0', 'passive_checks_enabled': '1', 'active_checks_enabled': '1', 'flap_detection_enabled': '1', 'is_flapping': '0', 'percent_state_change': '0', 'latency': '0.00368200009688735', 'execution_time': '0.009706', 'scheduled_downtime_depth': '0', 'notes': {}, 'notes_url': {}, 'action_url': {}}
There is bupkis on v2 of the API so I'm definitely finding my own way.
--SN
jmichaelson
Re: NagiosXI API v2 | Host Status 1 vs. Many query results
Post by jmichaelson »
You're getting deep into the guts of XI here. As such it would be helpful to know which version of XI, NDO, Core, etc. you're using
-Jason
snapier3
Post by snapier3 »
jmichaelson wrote: Thu Sep 26, 2024 2:14 pm You're getting deep into the guts of XI here. As such it would be helpful to know which version of XI, NDO, Core, etc. you're using
Instance in question is nothing special just a stock install.
Ubuntu 24.04
NagiosXI 1.2.2
In the progress of writing a component for use with Neptune and the singular result issue is havoc with development.
V1 of the API is quite well documented as V2 progresses it would be great if we could get some of the same, a roadmap even...
--SN
snapier3
Post by snapier3 »
I figured it out, we are now back to contacts and permissions...
:shock:
Man I seriously hope that the authentication on v2 gets better.
SMH
jmichaelson
If you have suggestions, I'd be happy to open a feature request with them for you! Of course we can't commit to anything here, but I can make the request.
-Jason
snapier3
Post by snapier3 »
If basic auth is going to be the method going forward which means it will remain unencrypted, can it handle Base64 Clear Text?
I mean it's still text but, I don't ever have to store or transmit usernames and passwords in plain text
I do hope that a basic authentication strategy is avoided for accessing the API.
This method will increase the toil associated in administering XI by adding the need to manage object contact association and current user permission configurations.
While the POST/PUT/DELETE for objects (that does not use raw import) get worked out the status classes can be extended for hostgroups,servicegroups,contacts, and commands in the same method as used with host and service classes.
Relying on the common.php isn't the most attractive for status calls but it does seem to work and still works with the limited query options that are currently available for these two.
  • status/host
    status/service
account/session returns a list, everything else returns a type of dict.
Documentation
Feature visibility in the NagiosXI Change Logs
bbahn
Post by bbahn »
Thanks for taking note of this. I have filed an issue for improving this.
Post Reply
