I am unable to display the icons on the map. They are correctly specified in the hosts' configuration and visible on the non-legacy map. How can I fix this? Thank you in advance
Raphael
icon in Map Legacy
icon in Map Legacy
- map_legacy.png (21.66 KiB) Viewed 197291 times
homer_2001
Re: icon in Map Legacy
have you solved the problem? Same problem here after update from ubuntu 22.04 to 24.04.
Homer
Homer
