I have some custom scripts that I need to move from our old core system to the new XI server.
I have placed them in /usr/local/nagios/libexec/ and I can run the check successfully on the command line with no issues.
# /usr/local/nagios/libexec/check_password_age.sh -w 10 -c 30
WARNING: The last password change for user was 22 days ago
But when I try to create a service in XI using the CCM I cannot find that in the list. And I did confirm that it is Admin --> manage plugins.
Am I putting the shell script in the wrong location? Is Nagios XI not pulling in for some reason?
Copy custom scripts from core to Nagios XI
robertmaddox
gwesterman
Re: Copy custom scripts from core to Nagios XI
Hi @robertmaddox,
In order to add your plugin to services, you will first have to define a command (CCM -> Commands). Once you define a command that calls your custom script, you can add the command to your new service(s). For more info, here is a detailed doc on the subject.
If you have any additional questions, please ask.
Thank you!
Thank you!
