I'm connecting to various codecs to get the packet drops information via snmp,
While it works fine with some of them, Nagios seems to be adding "c" to some of them
That "C" is not in data but it breaks the graphs:
[[email protected] ~]$ /usr/local/nagios/libexec/check_snmp -H xx.xx.xx.xx -o 'iptecPortRxPacketErrors.1' -C 'xxx' -P 2c -m IPTEC-SERVICES-VNP-MIB -v
/bin/snmpget -Le -t 3 -r 5 -m IPTEC-SERVICES-VNP-MIB -v 2c [context] [authpriv] xx.xx.xx.xx:161 iptecPortRxPacketErrors.1
IPTEC-PORTSERVICE-COMMON-MIB::iptecPortRxPacketErrors.1 = Counter32: 323
SNMP OK - 323 | IPTEC-PORTSERVICE-COMMON-MIB::iptecPortRxPacketErrors.1=323c
cneck_snmp -v2.4.5
Where is that "c" from and how can I get rid of it?
snmp bug (?)
DoubleDoubleA
Re: snmp bug (?)
Hi @svaertis23,
This may be a usage issue, and not a bug. There are two pieces of documentation I would point you to:
https://nagios-plugins.org/doc/guidelines.html
https://nagios-plugins.org/doc/man/check_snmp.html
If you look in the guidelines doc, you will see under Performance data, Notes:, 10.5, that the letter "c" denotes "a continous counter (such as bytes transmitted on an interface)".
If you then look at check_snmp under Rate Calculation at the bottom that you may want to be using the --rate option.
Your command you posted uses the -r option, which the help says is for REGEX.
If you meant to check for a rate of 5, you would want to use --rate rather than -r.
Let me know how that works for you.
Aaron
Aaron
svaertis23
Re: snmp bug (?)
Thank you but if I do this, this breaks the counter, now it just says:
SNMP RATE OK - 0
where it should return actual number of dropped packets:
SNMP OK - 269
Please advise,
Cheers
SNMP RATE OK - 0
SNMP OK - 269
Please advise,
Cheers
svaertis23
DoubleDoubleA
Re: snmp bug (?)
Awesome, thanks for letting me know!
