Check_udp for chronyd
Post Reply
janellewhitting
Post by janellewhitting »
I'm looking for an example of check_udp for a port. Any suggestion?
- Janelle -slope game
gwesterman
Re: Check_udp for chronyd
Post by gwesterman »
Hi @janellewhitting,
This forum post has a number of good examples for that plugin.
Let us know if this helps and if you have any additional questions.
Thank you!
vedicsystems
Post by vedicsystems »
The basic way to check if chronyd is running via UDP is to use check_udp -H <IP> -p 123. The Network Time Protocol (NTP) uses port 123, so this confirms the service is listening on that port.
Post Reply
