Nagios XI installatinon fails on Subcomponents
dawaggen
Post by dawaggen »
Hi!
I recently started my migration from CentOS to Ubuntu.
Version 2024R1.0.1
Ubuntu 22.04 is installed due to the version i was running on CentOS does not support the latest ubuntu version so i have to upgrade it afterwards.
This is a clean install.
This is the end of the install.log
# Failed test 'use Nagios::Monitoring::Plugin::Functions;'
Files=16, Tests=33, 1 wallclock secs ( 0.04 usr 0.01 sys + 0.68 cusr 0.08 csys = 0.81 CPU)
Result: FAIL
Failed 16/16 test programs. 32/33 subtests failed.
make: *** [Makefile:861: test_dynamic] Error 255
ERROR: Subcomponent 'extraplugins' installation failed - exiting.
Subcomponents installation failed - exiting
Failing every test on the sumconponents.
I am doing a local install with ./fullinstall
I´ve tried running the ./A-subcomponents separately but fails at the same place.
I´ve also tried running the fullinstallatino again but no success.
The installation is done from /tmp. I´ve given root full access to all the folders.
Install.log attached.
Regards
Rasmus
jmichaelson
Re: Nagios XI installatinon fails on Subcomponents
Post by jmichaelson »
I would recommend downloading the latest version of Nagios XI (2024R1.2.2) and installing that version.
-Jason
dawaggen
Post by dawaggen »
Hi!
Doesnt it have to be the exact same version when im doing a migration?
Regards
Rasmus
lgute
Post by lgute »
Hi @dawaggen,
Yes, both servers need to have the same version of XI.
Assuming you have CentOS 7/8, you can upgrade to 2024R1.1.5 and that may take care of your issue.
Nagios Software Supported OS Versions
-Laura
sgardil
Post by sgardil »
Hey @dawaggen
Is it the installation mainly that you are having issues with on Ubunutu 22? If so can you check your system to make sure that it is fully updated/upgraded and try another install? I was able to run an installation with no issues for that version so it may just be a loss of connection during install/needing an updated system.
DoubleDoubleA
Post by DoubleDoubleA »
Perhaps try
rpm --import https://oss.oracle.com/ol6/RPM-GPG-KEY-oracle
dawaggen
Post by dawaggen »
Thanks! That worked, i will try to install the new version on the ubuntu server now.
dawaggen
Post by dawaggen »
When trying to do a ./fullinstall now it says all the mysql passwords are wrong?
Should i reinstall mysql or do a full reinstall of the OS?
Regards
Rasmus
jsimon
Post by jsimon »
The simplest option might be reinstalling the OS or mysql. You could also determine what the current mysql passwords are and run the fullinstall script without the -n noninteractive flag, and provide the current passwords during the install process.
dawaggen
Post by dawaggen »
Hi, okay i will try to remove mysql and see if it works.
Weird because i know what the password was when i ran the fullinstall before that.
