Problem with nagios macros
karthick87
Post by karthick87 »
Recently I am not getting any email notification in nagios for hosts, where as i am getting email notification for all services. I am not receiving any email alerts in case any issue so that I tested it by sending custom host notification from WEBUI, something seems to be wrong in the log. I hope someone can help me. Please find the logs below,
From Nagios Frontend Webui: (Tested it by sending custom host notification)
Sep 24 20:43:00 ubuntubackup-chennai sendmail[5923]: q8OFD0bP005923: Authentication-Warning: localhost.localdomain: nagios set sender to nagiosub@****.com using -r
Sep 24 20:43:00 ubuntubackup-chennai sendmail[5923]: q8OFD0bP005923: from=nagiosub@****.com, size=436, class=0, nrcpts=1, msgid=<5060787c.cbQWUMyq0G8H5/8r%nagiosub@****.com>, relay=nagios@localhost
Sep 24 20:43:00 ubuntubackup-chennai sendmail[5924]: q8OFD0JV005924: <[email protected]>... User unknown
Sep 24 20:43:00 ubuntubackup-chennai sendmail[5923]: q8OFD0bP005923: to=$, ctladdr=nagiosub@****.com (496/492), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30436, relay=[127.0.0.1] [127.0.0.1], dsn=5.1.1, stat=User unknown
Sep 24 20:43:00 ubuntubackup-chennai sendmail[5924]: q8OFD0JV005924: from=<nagiosub@****.com>, size=436, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 20:43:00 ubuntubackup-chennai sendmail[5923]: q8OFD0bP005923: q8OFD0bQ005923: DSN: User unknown
Sep 24 20:43:01 ubuntubackup-chennai sendmail[5924]: q8OFD0JX005924: from=<>, size=2374, class=0, nrcpts=1, msgid=<[email protected]>, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 20:43:01 ubuntubackup-chennai sendmail[5923]: q8OFD0bQ005923: to=nagiosub@****.com, delay=00:00:01, xdelay=00:00:01, mailer=relay, pri=31460, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (q8OFD0JX005924 Message accepted for delivery)
Sep 24 20:43:02 ubuntubackup-chennai sendmail[5926]: q8OFD0JX005924: to=<nagiosub@****>, delay=00:00:02, xdelay=00:00:01, mailer=relay, pri=122374, relay=smtp10.netcore.co.in. [202.162.229.32], dsn=2.0.0, stat=Sent (_SMR_smtp12.netcore.co.in Ok: queued as 0797E19957)
I hope there is some problem with my macros. Can someone here guide me fix this issue pls?
