emerson network power ups snmp monitor on nagios
sreeram
Post by sreeram »
How to monitor snmp service on emerson network power ups using nagios core.
Thanks in advance
Sreeram
mguthrie
Re: emerson network power ups snmp monitor on nagios
Post by mguthrie »
I'd actually start with the check_ups plugin that ships with the Nagios Plugins package.
[root@DEV59 libexec]$ ./check_ups -h
check_ups v2023 (nagios-plugins 1.4.13)
Copyright (c) 2000 Tom Shields
Copyright (c) 2004 Alain Richard <[email protected]>
Copyright (c) 2004 Arnaud Quette <[email protected]>
Copyright (c) 2000-2007 Nagios Plugin Development Team
        <[email protected]>
This plugin tests the UPS service on the specified host. Network UPS Tools
from www.networkupstools.org must be running for thisplugin to work.
Usage:check_ups -H host -u ups [-p port] [-v variable] [-w warn_value] [-c crit_                         value] [-to to_sec] [-T]
Options:
 -h, --help
    Print detailed help screen
 -V, --version
    Print version information
 -H, --hostname=ADDRESS
    Host name, IP Address, or unix socket (must be an absolute path)
 -p, --port=INTEGER
    Port number (default: 3493)
 -u, --ups=STRING
    Name of UPS
 -T, --temperature
    Output of temperatures in Celsius
 -v, --variable=STRING
    Valid values for STRING are LINE, TEMP, BATTPCT or LOADPCT
 -w, --warning=DOUBLE
    Response time to result in warning status (seconds)
 -c, --critical=DOUBLE
    Response time to result in critical status (seconds)
 -t, --timeout=INTEGER
    Seconds before connection times out (default: 10)
These are some other results that came up.
http://exchange.nagios.org/index.php?op ... =check_ups
