remove_historical_data.sh - nagios_logentries only
Post Reply
gregbeyer
Post by gregbeyer »
I would like to clean up cruft in my nagios_logentries which I can tell has gotten huge and takes a long time to repair when I run repair-databases.sh. However remove_historical_data.sh, throws out not only logentries, but also performance history data, and other that I want to keep.
How can I clean up only logentries? Thanks.
bbahn
Re: remove_historical_data.sh - nagios_logentries only
Post by bbahn »
Hello @gregbeyer,
To clean up your nagios_logentries table without removing any historic data, I recommend using an SQL query.
I recommend creating backup before doing this so as to prevent accidental loss of data:
 mysqldump -u <root/nagios> -p <mysqlrootpass/mysqlnagiospass> > nagiosdb_backup.sql
Then you can delete your nagios log entries by logging into mysql,
mysql -u <root/nagios> -p
selecting your nagios table
use nagios;
and deleting nagios log entries before a certain date
DELETE FROM nagios_logentries WHERE entry_time < NOW() - INTERVAL 90 DAY;
This will delete any log entries from further than 90 days ago. You can update the interval as desired.
Since you are deleting a large number of table rows, it is recommended that you optimize your table afterwards using something like
OPTIMIZE TABLE nagios_logentries
gregbeyer
Post by gregbeyer »
Hello @bbahn, I've run your suggested commands, but it seems to make no difference in the sixe of my nagios_logentries.
First I ran repair_databases.sh, and it shows that nagios_logentries has Data records: 18,054,655.
Then I ran:
mysql> DELETE FROM nagios_logentries WHERE entry_time < NOW() - INTERVAL 30 DAY;
Query OK, 0 rows affected (24.60 sec)
mysql> OPTIMIZE TABLE nagios_logentries;
| Table | Op | Msg_type | Msg_text |
| nagios.nagios_logentries | optimize | status | OK |
1 row in set (15.15 sec)
0 rows affected??
Then I ran repair_databases again: Data records: 18070647. (18,070,647 to make easier to read)
So in the few minutes between first repair, Delete and second repair the table grew in size.
Post Reply
