Nagios non-legacy map
Post Reply
romanoarnaldi
Post by romanoarnaldi »
Hello!
I'm stuck on nagios core 4.5.2, since upgrading would remove the non-legacy map (viewtopic.php?t=75728).
Is there a way to upgrade nagios core and re-import the AngularJS files responsible for the non-legacy map?
bbahn
Re: Nagios non-legacy map
Post by bbahn »
Hello @romanoarnaldi,
I'm afraid that even if you do this, you'd run in to the same issue as the issue you linked.
If you wanted to have a still-working version, you'd have to build a custom branch of Nagios Core that doesn't have the map removed, but still contains the other updates. As this would require the maintenance of a separate Nagios Core project and keeps the security vulnerability present in your branch, I would not recommend this. If you are in desperate need of a replacement, I can file a feature request for you, but our dev team has a lot of priorities right now and it's unlikely that we'd be able to get to it in the near future.
Post Reply
