NCPA monitoring Adding Linux mounted disk
Post Reply
dancormack
Post by dancormack »
I have an existing linux server which is being monitored by Nagios XI. How do I add a new disk which I mounted to the server to the monitoring?
The mount point is: /ftp/testOracle/tvwi/home/temp01
I tried using core config and copied the disk monitor for the root directory and added the additional path but it I snot working. It says I may be trying to monitor the root volume or something.
danderson
Re: NCPA monitoring Adding Linux mounted disk
Post by danderson »
Thanks for reaching out @dancormack,
What is the command you are attempting to run that is giving you the error? Can you be more specific about the error?
Post Reply
