Monitor Lenovo XClarity Controller 2
Post Reply
riahc3
Post by riahc3 »
Hello
Nagios has recent, decent and modern plugins for iDRAC and iLO but I want to know if there is something for Lenovo XClarity Controller 2
Everything Ive found for now is pretty outdated and doesnt work in modern OS.
Could you recommend the best way to monitor this?
Thank you
danderson
Re: Monitor Lenovo XClarity Controller 2
Post by danderson »
Thanks for reaching out @riahc3,
I found this link
https://pubs.lenovo.com/xcc2/monitoring ... ver_status
You'd probably have to write or modify a plugin that scrapes this webpage to get the relevant information.
riahc3
Post by riahc3 »
danderson wrote: Wed Oct 30, 2024 1:16 pm Thanks for reaching out @riahc3,
I found this link
Thank you for your reply.
Seems unusual there isnt any plugin already made....Even if its old...if it works, it works.
No-one has any experience?
Also scraping the page with credentials and such seems like a bit of a nightmare
danderson
Post by danderson »
Scraping isn't terrible if you use Beautiful Soup in python. I believe a few plugins work by scraping a web page.
Otherwise, It looks like there are a few CLI options, including SNMP
https://pubs.lenovo.com/xcc2/dw1lm_r_snmpcommand
So you can follow these directions to set up SNMP and then using the SNMP wizard in XI.
Post Reply
