RESOLVED: Issue checking Vmware Hosts after uogarding to the lates version
slawek
Post by slawek »
I just upgraded to the latest version 2024R1.3 running on Ubuntu 24.04 LTS.
Now when Im trying to monitor Vmware Host using following command I'm getting following error:
python3 /usr/local/nagios/libexec/check_vsphere_xi.py -H "chi-esxi-01" -f "/usr/local/nagiosxi/etc/components/vsphere/chi_esxi_01_auth.txt" -l "CPU" "-w80" "-c90" "" "" "" ""
Traceback (most recent call last):
File "/usr/local/nagios/libexec/check_vsphere_xi.py", line 8, in <module>
from pyVim import connect
File "/usr/lib/python3/dist-packages/pyVim/connect.py", line 37, in <module>
from pyVmomi import vim, vmodl, SoapStubAdapter, SessionOrientedStub
File "/usr/lib/python3/dist-packages/pyVmomi/__init__.py", line 204, in <module>
from pyVmomi.SoapAdapter import SoapStubAdapter, StubAdapterBase, SoapCmdStubAdapter, \
File "/usr/lib/python3/dist-packages/pyVmomi/SoapAdapter.py", line 993, in <module>
_SocketWrapper = ssl.wrap_socket
AttributeError: module 'ssl' has no attribute 'wrap_socket'
Does anyone knows how to fix this issue?
lgute
Re: Issue checking Vmware Hosts after uogarding to the lates version
Post by lgute »
Hi @slawek, thanks for reaching out.
What version of Python 3 is running on your XI server?
In a terminal window...
python3 --version
-Laura
slawek
Post by slawek »
Python 3.12.3
gwesterman
Post by gwesterman »
What version of of pyvmomi (the python package) is installed?
Try upgrading that package if it is less than 8.0.3.0.
Thank you!
slawek
Post by slawek »
Hi, I just checked and I'm running latest available from repo. If i have to upgrade to the suggested version do you know how to do it?
apt-get install python3-pyvmomi
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
python3-pyvmomi is already the newest version (6.7.1-6).
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
When I'm trying to use pip to upgrade I'm getting following error and not sure how to solve it:
pip install --upgrade pyvmomi
error: externally-managed-environment
× This environment is externally managed
╰─> To install Python packages system-wide, try apt install
python3-xyz, where xyz is the package you are trying to
install.
If you wish to install a non-Debian-packaged Python package,
create a virtual environment using python3 -m venv path/to/venv.
Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
sure you have python3-full installed.
If you wish to install a non-Debian packaged Python application,
it may be easiest to use pipx install xyz, which will manage a
virtual environment for you. Make sure you have pipx installed.
See /usr/share/doc/python3.12/README.venv for more information.
note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
hint: See PEP 668 for the detailed specification.
Thank you for your help on this issue.
jsimon
Post by jsimon »
You should be able to upgrade like this:
apt upgrade python3-pyvmomi
slawek
Post by slawek »
When I'm trying to use apt im getting this:
gwesterman
Hi @slawek,
Try this:
apt install python3.12-venv
python3 -m venv .venv
source .venv/bin/activate
Let us know if that works for you.
Thank you!
slawek
Post by slawek »
I was able to run all above commands and they completed successfully, however when I'm trying to run check again I'm getting same error as before
bbahn
Post by bbahn »
Hello @slawek,
Can you run
python -m pip list
and post the contents here?
