DUO problems
zbuckingham
DUO problems
Post by zbuckingham »
I have already setup DUO for Nagios. I copy and pasted the all three required fields and turn DUO on. Whenever someone tries to sign in I get {"error": "invalid_grant", "error_description": "Invalid redirect URI 'https://*IP of server*/nagiosxi/login.php'."} On the URL I see the https://**DUOAPI.duosecurity.com/oauth/v1/authorize?response_type=code&client_id=DI2LIHTTX5FJV8I6TCX2&scope=openid&redirect_uri=https%3A%2F%2F10.233.65.35%2Fnagiosxi%2Flogin.php&request=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzUxMiJ9.eyJzY29wZSI6Im9wZW5pZCIsInJlZGlyZWN0X3VyaSI6Imh0dHBzOlwvXC8xMC4yMzMuNjUuMzVcL25hZ2lvc3hpXC9sb2dpbi5waHAiLCJjbGllbnRfaWQiOiJESTJMSUhUVFg1RkpWOEk2VENYMiIsImlzcyI6IkRJMkxJSFRUWDVGSlY4STZUQ1gyIiwiYXVkIjoiaHR0cHM6XC9cL2FwaS03NmY2Mjc2Ny5kdW9zZWN1cml0eS5jb20iLCJleHAiOjE3MzA5Mjg0OTAsInN0YXRlIjoiclFoS3Nnc0h6bUVVTHVQSXZlRzRFYmhraFFDUjZrQlY5Yk5uIiwicmVzcG9uc2VfdHlwZSI6ImNvZGUiLCJkdW9fdW5hbWUiOiJ6YnVja2luZ2hhbSIsInVzZV9kdW9fY29kZV9hdHRyaWJ1dGUiOnRydWV9.kGg5x9HC3wheU-sLlCne3cZGOm8Y7zu61RFKfBGk8R9DPFkV7Cx1HHobuBNCX_Tkf0f-ayH7fP3EfhZcuQBPTw
Does anyone know why this may be happening?
sgardil
Re: DUO problems
Post by sgardil »
zbuckingham wrote: Wed Nov 06, 2024 4:21 pm I have already setup DUO for Nagios. I copy and pasted the all three required fields and turn DUO on. Whenever someone tries to sign in I get {"error": "invalid_grant", "error_description": "Invalid redirect URI 'https://*IP of server*/nagiosxi/login.php'."} On the URL I see the https://**DUOAPI.duosecurity.com/oauth/v1/authorize?response_type=code&client_id=DI2LIHTTX5FJV8I6TCX2&scope=openid&redirect_uri=https%3A%2F%2F10.233.65.35%2Fnagiosxi%2Flogin.php&request=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzUxMiJ9.eyJzY29wZSI6Im9wZW5pZCIsInJlZGlyZWN0X3VyaSI6Imh0dHBzOlwvXC8xMC4yMzMuNjUuMzVcL25hZ2lvc3hpXC9sb2dpbi5waHAiLCJjbGllbnRfaWQiOiJESTJMSUhUVFg1RkpWOEk2VENYMiIsImlzcyI6IkRJMkxJSFRUWDVGSlY4STZUQ1gyIiwiYXVkIjoiaHR0cHM6XC9cL2FwaS03NmY2Mjc2Ny5kdW9zZWN1cml0eS5jb20iLCJleHAiOjE3MzA5Mjg0OTAsInN0YXRlIjoiclFoS3Nnc0h6bUVVTHVQSXZlRzRFYmhraFFDUjZrQlY5Yk5uIiwicmVzcG9uc2VfdHlwZSI6ImNvZGUiLCJkdW9fdW5hbWUiOiJ6YnVja2luZ2hhbSIsInVzZV9kdW9fY29kZV9hdHRyaWJ1dGUiOnRydWV9.kGg5x9HC3wheU-sLlCne3cZGOm8Y7zu61RFKfBGk8R9DPFkV7Cx1HHobuBNCX_Tkf0f-ayH7fP3EfhZcuQBPTw
Can you verify that the redirect uri is correct? Also when you go to system settings do you have an external url set? If not try setting that external url and see if it fixed the issue.
zbuckingham
Re: DUO problems
Thank you! I changed the URL redirect and that worked. Thank you!
sgardil
Re: DUO problems
Post by sgardil »
Glad to help. I am going to mark this thread as complete to help others that run into the same issue. If you have anymore questions feel free to reach out.
