We have been hardening server so I am pretty sure it is related.
Nagios XI and Core work fine just upgrade fails
From GUI
Latest Available Version: 2024R1.3.1
Installed Version: 2024R1.3
Last Update Check: 2024-11-13 10:38:11
On a Virtual Machine
DISTRO INFO:
Ubuntu
24.04
x86_64
Error:
chown: warning: '.' should be ':': ‘root.nagios’
Archive: sourceguardian/ixed4.lin.x86-64.zip
checkdir: cannot create extraction directory: /usr/lib64/php/modules
No such file or directory
From cmdline
root@<servername>:/tmp# tar xzf xi-latest.tar.gz
root@<servername>:/tmp# cd nagiosxi
root@<servername>:/tmp/nagiosxi# ./upgrade
-bash: ./upgrade: Permission denied
root@<servername>:/tmp/nagiosxi# bash upgrade
upgrade: line 9: ./init.sh: Permission denied
upgrade: line 14: ./xivar: Permission denied
upgrade: line 15: ./xivar: Permission denied
upgrade: line 16: ./xivar: Permission denied
upgrade: line 22: ./xivar: Permission denied
upgrade: line 176: upgrade: command not found
root@<servername>:/tmp/nagiosxi# bash ./upgrade
./upgrade: line 9: ./init.sh: Permission denied
./upgrade: line 14: ./xivar: Permission denied
./upgrade: line 15: ./xivar: Permission denied
./upgrade: line 16: ./xivar: Permission denied
./upgrade: line 22: ./xivar: Permission denied
./upgrade: line 176: ./upgrade: Permission denied
2024R1.3.1 Upgrade fails
Re: 2024R1.3.1 Upgrade fails
probably because i have noexec configured on partitions. Need to figure out which for gui vs /tmp is my best guess.
removing noexec gets further but then hit next error
DoubleDoubleA
Hi @tkaufman,
The chown warnings should be cleared up in the next release, and shouldn't be a blocker. It looks like permissions on that directory. Any luck?
Aaron
Aaron
Didn't have time to work on it today as we had other priorities.
I am going to take another stab at on Monday
very surprised this was the solution.
I just created the directories php/modules under /usr/lib64/
The directories stopped at /usr/lib64/
Once created the update completed.
I am trying to understand why.
Now under /usr/lib64/php/modules is one file.
ixed.8.3.lin
ixed.8.3.lin
My guess would be the security hardening was restricting permissions such that the active user couldn't create a directory under normal conditions. Creating the directory directly will usually solve errors like this, as the check will determine if the directory exists and use it rather than trying to create it if found. Are you running into any further issues with this upgrade?
No other issues cropped up.
I probably should have muddled my way through this more on my own.
It helps to sometimes just walk it out with others.
No worries! Glad you were able to get this resolved, social support is what the forums are here for
