OVA for Nagios 5.9
Post Reply
marcmooney-atos
OVA for Nagios 5.9
Post by marcmooney-atos »
I'm looking for an OVA for Nagios version 5.9, main portal only seems to have OVA for latest version. I'm setting up a test VM so I can upgrade from 5.9 to latest version (Live server is 5.9.0 version).Is there anywhere that I can download an OVA for 5.9?
Thanks.
DoubleDoubleA
Re: OVA for Nagios 5.9
Post by DoubleDoubleA »
Hi @marcmooney-atos,
As a matter of policy, we do not supply OVAs for older versions.
Aaron
sgardil
Post by sgardil »
marcmooney-atos wrote: Wed Nov 20, 2024 3:56 am Hi,
Thanks.
Hey @marcmooney-atos
Do you need to have an OVA or can you use a tarball with a manual install? Is your Xi instance an OVA instance currently? If you are on an OVA and you need to upgrade, unless you can do so in the gui you may need to do a back up and restore on a tarball build since we no longer host the 5.9.0 ova.
Previous tarball versions:
https://assets.nagios.com/downloads/nag ... rsions.php
Docs for backup and restoring:
marcmooney-atos
Thanks for this information, I may look at the manual option, seems it will be less complicated.
Post Reply
