Regards.
Upgrade from Core 4.4.13 to CSP
The download links at https://www.nagios.org/ for CSP do not work for me under Ubuntu 24.10 Firefox 132.0.2 or Chrome Version 127.0.6533.72 (Official Build) (64-bit). Is there an alternate way to for me to upgrade to CSP (if it is FREE!
)? Thanks.
Regards.
Regards.
gwesterman
Re: Upgrade from Core 4.4.13 to CSP
Hi @baqwas,
In order to go from Core to CSP, you will have to migrate (info here) rather than directly upgrade.
Have you tried just installing CSP on Ubuntu 24? If that's what you meant, what errors do you get?
Thank you!
Thank you!
Hello @gwesterman,
Thanks for the reply. Unfortunately, the link that you provided is precisely the one that I am having difficulty drilling down. The first click works, but then the follow-through fails.
Yes, I understand the fine print about the upgrade. I would be just as happy to simply upgrade to 4.5.x, but that too leads me to this CSP link that is broken at the succeeding click.
Regards.
Regards.
gwesterman
Hi @baqwas,
So you are having issues installing CSP (from this link: https://go.nagios.org/get-csp-zip) on Ubuntu 24? What is the error you are receiving?
Unable to connect
An error occurred during a connection to go.nagios.org.
The site could be temporarily unavailable or too busy. Try again in a few moments.
If you are unable to load any pages, check your computer’s network connection.
If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the web.
Firefox 133.0 (64-bit)
Ubuntu 24.10 (all basic update/upgrade completed as of 12/4)
I'm at 4.4.13 with Nagios Core; I just want to upgrade to the advertised 4.5.8. CSP is nice candy, but sincerely I will just as happy to get a link to 4.5.8.
Of course, there must be something wrong with my platform for this link (the one that you provided which is the same one that I have been trying to navigate from the Nagios website as well as my Nagios Core webpage which serves the same link through an intermediate page at the Nagios Core official website) to respond in this manner (and nobody else may have reported it). Just need a little nudge in the right direction. Thanks.
Regards.
I wouldn't be able to correspond with you, @gwesterman, if the above phrase was not previously validated.make sure that Firefox is permitted to access the web
Regards.
The link has not changed, my issue still exists... I'm the loser because I don't know what I'm missing with the update/upgrade. As the refrain goes, so much to learn, so little time to learn, I guess I'll stay in my shell.
dianereese
Hi @baqwas,
Try checking https://github.com/NagiosEnterprisesgeometry dash lite for CSP download links or email [email protected] for help. CSP has a free XI license for personal use with node limits. Let you know if it works!
Thanks, @dianereese.
If my understanding is correct, I have to do a fresh install of CSP. I'll definitely provide an update to the community when I proceed with the upgrade.
Regards.
Regards.
@baqwas,
This is correct. CSP, like XI is intended to be installed on a clean system.
AI Music Generator Free Online.
It allows you to turn text prompts into original songs quickly, which is great for experimenting with ideas and exploring AI-generated music without a complicated setup.
