[root@NagiosSRV ~]# service nagios status
Redirecting to /bin/systemctl status nagios.service
× nagios.service - Nagios Core 4.5.3
Loaded: loaded (/usr/lib/systemd/system/nagios.service; enabled; preset: disabled)
Active: failed (Result: exit-code) since Wed 2024-11-27 11:18:45 CET; 2h 54min ago
Duration: 274ms
Docs: https://www.nagios.org/documentation
Process: 1384078 ExecStartPre=/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg (code=exited, status=0/SUCC>
Process: 1384079 ExecStart=/usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg (code=exited, status=0/SUCCESS)
Process: 1384111 ExecStopPost=/bin/rm -f /usr/local/nagios/var/rw/nagios.cmd (code=exited, status=0/SUCCESS)
Main PID: 1384080 (code=exited, status=254)
CPU: 183ms
Nov 27 11:18:45 NagiosSRV nagios[1384080]: wproc: Registry request: name=Core Worker 1384084;pid=1384084
Nov 27 11:18:45 NagiosSRV nagios[1384080]: wproc: Registry request: name=Core Worker 1384081;pid=1384081
Nov 27 11:18:45 NagiosSRV nagios[1384080]: wproc: Registry request: name=Core Worker 1384083;pid=1384083
Nov 27 11:18:45 NagiosSRV nagios[1384080]: Event broker module '/usr/local/nagios/bin/ndo.so' initialized successfully.
Nov 27 11:18:45 NagiosSRV nagios[1384080]: Warning: Service 'CPU Usage - Modified' on host 'SRV-PRINT-01' has a notifica>
Nov 27 11:18:45 NagiosSRV nagios[1384080]: Successfully launched command file worker with pid 1384109
Nov 27 11:18:45 NagiosSRV nagios[1384080]: Caught SIGSEGV, shutting down...
Nov 27 11:18:45 NagiosSRV systemd[1]: nagios.service: Main process exited, code=exited, status=254/n/a
Nov 27 11:18:45 NagiosSRV nagios[1384109]: Caught SIGTERM, shutting down...
Nov 27 11:18:45 NagiosSRV systemd[1]: nagios.service: Failed with result 'exit-code'.
Monitoring engine wont start
Can anyone help us? We just upgraded from Nagios 5.9.1 to 2024R1.3.1 and now we couldn't make the monitoring engines starts
DoubleDoubleA
Re: Monitoring engine wont start
Hi @11abbidoa,
Did you see gwesterman's reply to your co-worker's thread on this issue? viewtopic.php?t=75929
Aaron
Aaron
