NagiosXI HA on ServiceGaurd cluster
Post Reply
Prashant23
Post by Prashant23 »
Hi Team,
Is NagiosXI application supports HA on ServiceGaurd cluster.
What are the pre-checks and post checks to configure NagiosXI HA on ServiceGaurd cluster.
Thanks in advance.
kg2857
Re: NagiosXI HA on ServiceGaurd cluster
Post by kg2857 »
If you want nagios to be HA, here are a few links. If you want nagios to monitor SG, you might check the exchange site.
My low buck solution was to copy a backup to the second nagios host and restore it. This worked fine for 10 years on 10 systems (20 nagios hosts). The only failure was when someone cleverly deleted both nagios hosts. That said, I never had to fail over to the 2nd system for anything other than testing. All the nagios hosts were virtual.
https://www.google.com/search?q=nagios+ ... s-wiz-serp
Post Reply
