I receive an Event Log from Windows with a HostName in message field like "NBADM01" or "NBUSR02".
I'm trying to create a row with a "terms" table in order to count the total of HostName and fill in a bar-like graph.
If I put "message" in field I can view a bar with the right number but all in one bar named "missing field".
It seems I cannot filter the message field. I can filter all other fields.
Why???
Thank you in advance.
Graziano.
Create a terms with field "message" in a dashboard
HowardJackson
Re: Create a terms with field "message" in a dashboard
Ensure that the message field is being correctly extracted and parsed. Sometimes, if the field is not properly extracted, it might appear as missing field.
- jmichaelson
THe key here is definitely going to be to ensure that the message field is parsed correctly. In a table you can click on a log entry and it will bring up all the fields that Nagios Log Server has parsed so you can verify it.
-Jason
-Jason
