Specific service check for windows server
Post Reply
abw_framatome
Post by abw_framatome »
I'm trying create a service check on a windows server for a particular windows service.
NetBackup Client Service
Running Nagios Core 4.3.4
NSClient++
I'm not familiar with writing a specific service check within Nagios. Any suggestions on where to start?
MaterazziSan
Re: Specific service check for windows server
Post by MaterazziSan »
Maybe you can start with https://assets.nagios.com/downloads/nag ... ndows.html.
Best regards
kg2857
Post by kg2857 »
It looks like nsclient has an internal service check.
https://nsclient.org/docs/reference/win ... ck_service
Have a look at nsclient.ini to see if a service check is defined already.
Post Reply
