Securing Credentials in snmptrapd.conf on Offline RHEL Server
Post Reply
kenneth59
Post by kenneth59 »
Hi All,
I am working in an offline RHEL environment and am seeking a method to secure the snmptrapd.conf file to prevent credentials from being stored in plain text while ensuring the snmptrapd service continues to run seamlessly.
I understand that SNMP v3 provides encryption for transmitted traps, but my primary concern is securing the credentials within the snmptrapd.conf file itself.
Could anyone please advise on any best practices, tools, or methods available to achieve this?
jsimon
Re: Securing Credentials in snmptrapd.conf on Offline RHEL Server
Post by jsimon »
Hi @kenneth59,
Taking a look at the man page for snmptrapd.conf, it looks like there is support for creating users with encrypted usernames as well as passwords. Useage from the manual is as follows:
createUser [-e  ENGINEID] username (MD5|SHA|SHA-512|SHA-384|SHA-256|SHA-224) authpassphrase [DES|AES]
              See  the snmpd.conf(5) manual page for a description of how to create SNMPv3 users.  This is roughly the same, but the file
              name changes to snmptrapd.conf from snmpd.conf.
Let us know if you have any related questions
kenneth59
Post by kenneth59 »
Hi @jsimon,
Thank you for your response. Do correct me if I’m mistaken. I checked the following link (http://www.net-snmp.org/docs/man/snmptrapd.conf.html), but I couldn’t find anything related to the method you mentioned. However, upon reviewing http://www.net-snmp.org/docs/man/snmpd.conf.html, I noticed some details in the manual that resemble what you described in your code section. After testing, it seems that this approach prevents the password from being displayed in plain text, but it appears to apply only to polling.
What I’m specifically looking for is a method to avoid storing trap passwords in snmptrapd.conf. Additionally, could you clarify the potential impact of a leaked SNMP trap password? From my understanding, the trap password is used primarily for decrypting traps sent from a server. Other than gaining access to the transmitted trap data, what other risks could this pose?
jsimon
Post by jsimon »
It looks like the docs you linked to haven't been updated in quite a while. I see that the version I get when I run
man 5 snmptrapd.conf
shows me a bit more information about the user setup process, and I would advise referencing the latest version of the documentation to make sure your steps are accurate.
Assuming you are using SNMPv3 for your trap transmission, and using the authPriv configuration, there are two separate passwords in use here.
createUser [-e ENGINEID] username (MD5|SHA|SHA-512|SHA-384|SHA-256|SHA-224) authpassphrase [DES|AES] [privpassphrase]
authpassphrase is the password used to authenticate the connection
privpassphrase is the password used to encrypt/decrypt the data
It looks like both passwords are hashed and stored, so neither should be available in plain text.
kenneth59
Post by kenneth59 »
Hi @jsimon,
jsimon wrote: Wed Dec 18, 2024 11:56 am createUser [-e ENGINEID] username (MD5|SHA|SHA-512|SHA-384|SHA-256|SHA-224) authpassphrase [DES|AES] [privpassphrase]
I would like to clarify the method you mentioned. Does it require saving the credentials in the /etc/snmp/snmptrapd.conf file, similar to the SNMP v3 configuration described in https://support.nagios.com/kb/article/s ... p-493.html?
#The commands above required the following settings in /etc/snmp/snmptrapd.conf
disableAuthorization yes
traphandle default /usr/sbin/snmptthandler
createUser -e 0x090807060504030201 the_user_name SHA the_SHA_string AES the_AES_string
authUser log,execute,net the_user_name
When I mentioned the need for credentials to be encrypted, I was referring to ensuring that if someone logs into the server and opens the /etc/snmp/snmptrapd.conf file, they should not be able to view the password in plain text. Is it possible to achieve this level of security?
kg2857
Post by kg2857 »
This has nothing to do with nagios and while it may help you to ask for support, it might be more usefull to ask on an snmp site.
jsimon
Post by jsimon »
@kenneth59,
That level of security appears to be what the encryption is explicitly for, according to documentation I was able to find. The password is stored in plain text for a few seconds and then is replaced with the hashed output permanently. I would suggest playing around with the configuration and seeing if you can confirm this. Or, as @kg2857 has suggested, you may find more help posting on snmp-related forums or sites with more questions.
kenneth59
Post by kenneth59 »
Hi @jsimon and @kg2857,
Thank you very much for your help. I’ll follow your suggestion and check on SNMP-related forums.
kg2857
Post by kg2857 »
You could also read the snmptrapd documentation. It would probably help the OP to learn a bit rather than just asking others to give them the answer.
Post Reply
