We are using RHEL 6.3 64 bit. We had install Nagios XI 2011R3.2, but some OS issue server suddenly hang, then we restore back up and its working, but due to cause Nagios was not working, it was showing some library missing. For we upgrade nagios, but problem was still, then we took tar backup of nagios and nagiosxi folder from local system /usr/local and reinstall Nagios XI 2011R3.2. We are using remote MySQL server for database. After re installation we have migrate data as per attached pdf and restore nagios and nagiosxi folder on local system. Now we can show all devices and its status at Nagios home page, but host and services not reflecting in core config manager, also getting error in apply verification. We check all configuration user also permission and all are correct. Herewith attached screenshot of issue. Please check and do the needful.
Pdf could not attached: Name as Nagios XI – Offloading MySQL to Remote Server
Host and services not reflecting in core config manager
wiproltdwiv
Re: Host and services not reflecting in core config manager
From here I think your best solution would be to use the Import tool in the Core Config Manager to bring all of your configs back into the database. Import all of your configs except for those in the etc/static directory.
http://assets.nagios.com/downloads/nagi ... nto_XI.pdf
Once the configs are imported, use the Write Config Tool to manually write new config files, verify, and fix any issues that remain in the Core Config Manager.
wiproltdwiv
Thanks its working as per your solution.
Good deal, glad it's working again!
