Hi All,
I am trying to upgrade NagiosXI from 5.9.1 to 5.11.3 but upgrade is failed with below error. Please help.
Curl error (37): Couldn't read a file:// file for file:///etc/pki/rpm-gpg/RPM-GPG-KEY-NAGIOS-V3 [Couldn't open file /etc/pki/rpm-gpg/RPM-GPG-KEY-NAGIOS-V3]
Upgrade fails with GPG key error
Re: Upgrade fails with GPG key error
What OS is this on? The issue looks like its due to local software repositories not being available. It has nothing to do with nagios.
Its helpful to provide relevant info info in posts.
DoubleDoubleA
Hi @Prashant23,
You can find the Nagios v3 public key here https://repo.nagios.com/GPG-KEY-NAGIOS-V3.
Aaron
Aaron
Prashant23
we already imported "GPG-KEY-NAGIOS-V3 " on server
@Prashant23,
It seems to me like a permissions error on your GPG key. Can you check the permissions on your GPG key to ensure the installer can read it?
Post
ls -l /etc/pki/rpm-gpg/RPM-GPG-KEY-NAGIOS-V3
Prashant23
Ran below command on servers and its completed but RPMGPG-KEY-NAGIOS-V3 not showing on server. What needs to do, please suggest.
wget https://repo.nagios.com/GPG-KEY-NAGIOS-V3
rpm --import GPG-KEY-NAGIOS-V3
OS: RHEL 9.2
[root@XXXXXXX tmp]# ls -lrt /etc/pki/rpm-gpg/
total 32
-rw-r--r-- 1 root root 3109 Oct 28 2017 RPM-GPG-KEY-NAGIOS-V2
-rw-r--r--. 1 root root 12807 Nov 17 2020 rhn-org-trusted-ssl-cert-1.0-1.noarch.rpm
-rw-r--r-- 1 root root 1656 Dec 1 2021 RPM-GPG-KEY-EPEL-9
-rw-r--r--. 1 root root 3682 Mar 28 2023 RPM-GPG-KEY-redhat-release
-rw-r--r--. 1 root root 1669 Mar 28 2023 RPM-GPG-KEY-redhat-beta
[root@XXXXXXX tmp]#
OS: RHEL 9.2
total 32
[root@XXXXXXX tmp]#
gwesterman
I recommend snapshotting your server before trying this, but give this a go:
Let us know how if it works.
Thank you!
yum -y remove nagios-repo && yum -y install https://repo.nagios.com/nagios/9/nagios-repo-9-2.el9.noarch.rpmThank you!
