I started my Nagiosxi VM (CentOS 6.3) this morning, clicked on Service Details and all of a sudden I cant find my monitored services in Service Status.
However, I can still see all hosts under Host Status and under Core Config Manager I could still find all the services there.
What could have caused this and how can I get nagiosxi to monitor this services again?
Cant Find all my monitored services in Service Status
Re: Cant Find all my monitored services in Service Status
Before this happened, had you done anything major to the system? Any sort of update, or config write with Nagios? Are the services visible anywhere else but the Core Config Manager?
No, I did nothing but shutdown the server at COB then when I Started the server the next working day, the services were not being monitored. I can only see them in the Core Config Manager.
This sounds like database corruption. Run the following procedure
http://library.nagios.com/library/produ ... i-database
Thanks Scott,
That did the magic.
Thanks.
That did the magic.
Thanks.
