Bug in check_vsphere_xi.py
Post Reply
triegel
Post by triegel »
Not sure if this is the correct forum to address this, so apologies in advance if not.
In working to utilize the "new" python check for VMware resources I ran into a bit of an edge case with how the check_vsphere_xi.py script handles the password value when consumed from an auth file.
Currently the password value is extracted with:
password = line.split("=")[1].rstrip()
which won't properly capture the entire password if that password contains a "=" symbol. Patching this to instead be:
password = line.split("=", 1)[1].rstrip()
should fix the issue.
Just wanted to pass this along, in the very least to help anyone with this very specific issue.
bbahn
Re: Bug in check_vsphere_xi.py
Post by bbahn »
Hello @trigel,
Good catch! I've made the fix for the username/password splits and will have it out in the next release (not 2024R2 as that's already into QA, but the next release).
triegel
Post by triegel »
Awesome! Thank you @bbahn!
Post Reply
