disable email from automysqlbackup
Post Reply
CAUARqq6815IeV9X
Post by CAUARqq6815IeV9X »
Where can I disable the emails from automysqlbackup process which are going to [email protected]? I don't want to receive any emails if no action is required, and also don't want anything going to root.
kfanselow
Re: disable email from automysqlbackup
Post by kfanselow »
So automysqlbackup is a shell script that resides in root's home directory ( usually /root/scripts/automysqlbackup ) and is run via cron. You can edit the script directly and change the email address ( around line 58 ) or you can comment out the lines with the mail commands ( including one using mutt ) to stop messages completely.
Hope this is useful !!!
Post Reply
