Results showing differently
Pratapa
Post by Pratapa »
We are using Nagios core 4.4.4
When we run a script on the remote machine (which is a Linux machine, RHEL 7.8 ) we are getting expected output whereas when we invoke it from the nagios server it is giving different output.
On Remote Host :
nagios@dd2ukytp201>/usr/bin/sudo /usr/lib64/nagios/plugins/check_all_fs.py 81 91
WARNING -- /opt filesystem breached warning level 18% free
df -k /opt
it is 82% full and showing correct results.
where as on Nagios server when we execute it is showing different results.(executed with nagios user)
./check_nrpe -H dd2ukytp201 -n -t 300 -c check_root_df -a 81 91
WARNING - /opt/opnv/netebackup filesystem breached warning level 12% free
However /opt/opnv/netbackup is 70% free on the remote host.
Not sure why it is showing differently on Nagios server.
DoubleDoubleA
Re: Results showing differently
Post by DoubleDoubleA »
Hi @Pratapa,
Where did you get check_all_fs.py?
Why does one report on /opt and the other on /opt/opnv/netbackup ?
I'd probably want to look at your plugin and also compare your command definition for check_root_df to running the plugin locally on the remote host with check_all_fs.py 81 91 .
A lot of times when things don't work but you'd really think they should, I like to go looking for a typo or some other slight (and easy to miss) mis-configuration.
Aaron
kg2857
Post by kg2857 »
Post the nrpe command check_root_df that gets executed for this check.
The command and what's being run from the shell aren't the same.
Pratapa
Post by Pratapa »
This issue is resolved.
Issue is with IP addres.
DoubleDoubleA
Thanks for reporting it solved!
Aaron
